View Full Version : Low miles sediment in pan
JJSmitches
02-10-2007, 01:21 PM
I recently had to drop the pan on my 700r4 and noticed the bottom was coated with a thin layer of graphite colored sediment. The trans has less than 500 miles. Is some sediment normal for a new trans that is just being broken in?
Should I be concerned?
All the shifts seem fine, I am going to refill and take it for another test drive to make sure it holds each gear and down shifts as it should.
I will come back with results tonight or tomorrow.
Thanks.
myclone
02-10-2007, 03:25 PM
Thanks.
Some graphite looking stuff in the pan is pretty much normal but a pic of the pan with the gunk would help.
Jayco_Automotive
02-10-2007, 06:40 PM
the substance you refered to is carbon that is put in transmission fluid as its manufactured
