View Full Version : Art Morrison's new frame?
Tyson A
02-09-2007, 06:11 PM
Does anybody have any pictures of the new AME frame coming out for the 1st gen Camaro's?
dhutton
02-10-2007, 08:29 AM
Here is one that they sent me. I think they are now shipping.
CraigMorrison
02-10-2007, 04:54 PM
Are you talking about the subframe or the full frame? The sub is posted above and the full frame is basically done.
Madspeed
02-10-2007, 06:34 PM
Wow things are starting to look up for us first gen guys
I like the fact that peeps are utalizing newer technoligy and not the tired rustang 2 stuff
Craig How is all the geomitry on this new sub?
were there any compromises?
Any one????
Tyson A
02-10-2007, 09:10 PM
I was asking about the sub. I did not know there was a full frame. Thanks alot now my head is starting to spin out of control. Full frame or sub, full frame or sub, full frame or sub. AWH!!! I'm getting dizzy
If you have a picture and don't mind could you post it or . Also what price range are we talking about.
CraigMorrison
02-12-2007, 05:43 AM
https://static1.pt-content.com/images/pt/2007/02/_MG_3233vi-1.jpg
https://static1.pt-content.com/images/pt/2007/02/_MG_3247vi-1.jpg
This is the start of the chassis. Note that the rear rails are duplicates of the OE rear subframe and are designed to fit under the trunk sheetmetal. The front is the same kick at what we have on our subframe. We are going to be adding front body mounts, bumper mounts and engine and trans mounts. This will eliminate quite a bit of the fab work that is required. As far as floor mods go, you will still have to go with a flat floor, but that has been reduced a bit as well... What we have had customers do is save the OE trans tunnnel/driveshaft tunnel and use that with the new floor. This chassis also features our new dropped arm C5 front suspension and 3-link rear suspension.
More pics here- http://public.fotki.com/CraigMorrison/max-g-3-link-chassis/
rockdogz
02-12-2007, 08:13 AM
:cool:
Sweet.... Have any 1st gens been built with the full frame yet?
wiedemab
02-12-2007, 08:53 AM
That thing is beautiful! Nice Work!
69TAPoser
02-12-2007, 09:12 AM
Ooooh baby! :drool:
Any idea of cost yet?
Phil
Tyson A
02-12-2007, 09:17 AM
Craig that is a work of art . Is there a expected release date with all the mounts.
68sixspeed
02-12-2007, 09:37 AM
Very nice... where was this 13 years ago when I was cutting out unibody frame rails and fabing 2x4 box tubing for my 68's full frame. Now you have me reconsidering my approach for the '69 project I'm working on. When will you have cost info? -Dan
Ricoch3T
02-12-2007, 12:42 PM
That looks great!!!! So you say a custom floor is needed when using that? Will the frame fit the 335's out back and something such as a 275 or wider in the front?
CraigMorrison
02-12-2007, 01:45 PM
To answer a few questions-
We've done quite a few of the first gen Camaros with our current MaxG platform but like I said, the one pictured above is brand new.
275's / 335's definitely won't be a problem
Price- its difficult to say because of options. But the "as pictured" price for the above chassis is around 10k.
Mr.VENGEANCE
02-12-2007, 03:35 PM
and worth every penny..
too bad i dont have that many pennys..
68sixspeed
02-12-2007, 04:39 PM
Craig- How is the front end setup? Did you modify the hub-to-hub width from the c5 specs to allow use of more normal backspace rims, or does it require corvette type backspace rims? That was always one of my pet-peeves on the c4 type front ends- great idea but they ended up with flat face rims on the front and normal backspaced rims on the rear.
Also, if you did adjust the track width, how's the geometry? Street good or road race good? thanks- Dan
TnBlkC230WZ
02-12-2007, 06:49 PM
I would be estatic if I could afford the frond subframe
silver69camaro
02-13-2007, 09:02 AM
I'll go ahead and answer this. The hub to hub on our Camaro-spec front ends is 60.5" to make wheels more affordable, just adjust your backspace by 1/4" to make 'em fit (60" is stock). This does increase the scrub slightly, but is a good thing in this case. It has just enough scrub to give a little feedback to the driver.
We didn't just take the C5 geometry and narrow the hub track, we modified the geometry to better fit the cars it will be installed on...frankly, it's better than stock C5. Like you said, it's road race good. This subframe combined with a well-thought out rear suspension and tires will scare the crap out the guy in the passenger seat.:headbang:
Tony@AirRideTech
02-13-2007, 09:33 AM
Craig, Silver..... To get you guys up to speed, the new Shockwave that we created for you guys for this chassis for fitment, Should be hitting the door anyday..... let me know if you have any questions or need anything ..... thanks guys!
ProdigyCustoms
02-13-2007, 09:40 AM
Thanks for sending that Tony. As soon as that hits the door and Craig says hell yeah, I have at least one or two more frames sold.
CraigMorrison
02-13-2007, 09:55 AM
Thanks for the update Tony! See you at Indy?
Frank- Thanks for the heads up! I guess we gotta make 'em fit!
silver69camaro
02-13-2007, 11:25 AM
Thanks Tony, we'll let you know as soon as we bolt 'em up.
71Formula
02-13-2007, 11:44 AM
I fully realize that I am probably exposing my lack of knowledge about chassis fitment, but would this full frame work on a second gen camaro/firebird as well?
I realize that they have different frames from the factory, however they have similar dimensions, and this frame requires custom floor pans anyways, so would it work, or am I missing something here?
silver69camaro
02-13-2007, 12:12 PM
Well, we're kinda talking about two different frames here. First is our first gen bolt-in subframe, which obviously requires no mods for installation. Bolt on and go.
Second, is the Max-G platform. This is a full-frame, weld-in, all-out performance setup. This type of frame can be had for just about any car - in fact, I just designed one for a '56 Buick...so a second gen is no problem. It uses the same suspension as our GT Sport subframe, but includes your choice of rear suspensions (3-link, triangulated 4-bar, etc).
But hold on, a 2nd gen bolt-in subframe may be in the works.
Karch
02-13-2007, 11:24 PM
Great, now I need to find a project (and sell the house).
J2speedandcustom
02-14-2007, 06:42 AM
Damn that's a great price for what you get!
Tony@AirRideTech
02-14-2007, 03:15 PM
Great ! ... they should have a set if single adjustables up there any time for the fronts. The rear should be a piece of cake with a 7000. Craig or Silver.... do you remember your rough ride height measurement on the rear coil over? and are you using a bearing on the coil overs as well?
CraigMorrison
02-14-2007, 05:58 PM
PM sent.
That's absolutely beautiful. Maybe this has been asked before, but I couldn't find it mentioned anywhere...
How much does that chassis weigh as pictured above (with all the suspension pieces shown)?
CraigMorrison
02-20-2007, 05:31 AM
This frame that's pictured will be our display chassis at the Goodguys shows that we go to. I'll see if I can't a weight before we dress it out.
jason@gmachine
02-21-2007, 09:31 PM
very nice clean work Carig. I really like the layout of the framerails and the use of the exhaust cut outs, very badass nice tucked away look for the exhaust. Is this thing MIG or TIG welded, and what material are you using for the arms in front? Are those the ATS spindles? What kind of heims are you using in the rear? And the final question, do you offer a full caged version?
Jason
