View Full Version : Accel GEN 7
Motown 454
02-04-2007, 06:42 PM
Hi this maybe a foolish question but will a Gen 7 system to upgrade to EFI on a small block 1st gen work to run an LS engine if I decide to go that way later ?
ProdigyCustoms
02-04-2007, 08:31 PM
With some add on stuff, yes. But you will have to get with Accel to find out exactly what you will need to add.
EFI69Cam
02-05-2007, 06:53 AM
I have a gen 7 and like it. But if I was going to buy a ECM today it would be a Big Stuff 3. The BS3 is even more flexible than the Accel, without having to find places for 18 black boxes to add the options.
Motown 454
02-10-2007, 03:50 PM
Thank you
Hammered
02-10-2007, 06:13 PM
18? I have the Gen7, SFI with WB02 and only had to hide two boxes. Except for the fuel rails and injectors, you wouldn't know I have EFI. However, I too would go with something different, probably the FAST XFI. Accel makes it too difficult for the customer to be successful.
EFI69Cam
02-11-2007, 11:48 AM
I'm exaggerating, but my setup consists of the ECU, fast EDIST, and wb02. Add transmission control and you have 4 boxes. The BS3 can do all of that on one box. Space is at a premium in a 1st gen. I still don't know where I am going to put my ECU. I might have to mount it in the engine compartment.
Hammered
02-11-2007, 06:07 PM
I see now. Take a look at the engine and efi sections on my website and you can see where I hid everything. I put the ECU under the front of the console.
EFI69Cam
02-11-2007, 06:36 PM
I like where you put your ECU. My car has gauges in the console, I don't know if it will fit there or not.
Your car and EFI install look really nice.:twothumbs
Hammered
02-13-2007, 06:39 AM
Thanks, I appreciate the compliments.
Are you running AC? If not, there may be enough room above or to the right of the glove box. I also thought about putting it under one of the seats or on an RS relay like panel under the driver fender.
John
