View Full Version : 10 bolt 8.5 posi
molyorange 77
01-30-2007, 07:07 AM
I need a new posi unit, I am in the market because the old carrier is cracked and the clutches are worn out. Im thinking about an Eaton clutch type or Detroit Locker or the Detroit Truetrac. Which one is mostly used out there?
Turbo Hen
01-30-2007, 03:01 PM
Eaton clutch type is like a factory unit......so they would be the most common type. Great posi for a frequently drive car.
-Carm
big gear head
01-30-2007, 06:45 PM
Depends on what you want to do with the car. If it will be a street/strip car then the Eaton is probably the best. If it will be drag raced a lot then the Detroit Locker would be better. If it will be taking curves fast then the Truetrac is better. What do you want it to do?
molyorange 77
01-31-2007, 08:37 AM
No drag strip use, Mostly street and a few SCCA events
Twin_Turbo
01-31-2007, 11:56 AM
if you get an eaton, the carriers are fine but the clutches and spiders are junk, better get some steel clutches (not the fan type) and the forged 17-10 gears the powder machined ones aren't too great either.
molyorange 77
01-31-2007, 01:49 PM
who carries the clutches and spider gears, what about the steels in the clutch pack are they any good or do they need to be replaced along with the friction disc.(Explain fan type clutch disc)
ProdigyCustoms
01-31-2007, 02:56 PM
We sell a lot of Moser stuff, and Tru Tracks are all the rage. And I never hear any complaints.
big gear head
01-31-2007, 05:30 PM
If you want to do the SCCA stuff then the Truetrac would be best.
molyorange 77
02-01-2007, 09:45 AM
Truetrac it is! Thanks guys for all the input and suggestions. NOW who has the best prices,need a ring and pinion too
big gear head
02-01-2007, 06:41 PM
Send me an email and I'll see what I can do. [email protected]
molyorange 77
03-19-2007, 10:50 AM
Truetracs are pretty awesome, got my ring and pinion set up friday and have to say I have always used clutch type diffs and thought they could not better the design but the truetrac is great. Now for the ring and pinion break in and I'll be ready to bruise the streets. I highly recommend this differential unit if street driven!
chevella
03-19-2007, 11:31 AM
Molyorange,
So you got it back together, great! What gear ratio did you go with? How about the 2 black lines, do i need to check out Hwy 27?
molyorange 77
03-19-2007, 12:51 PM
Whats up chevella, I have not layed any black patches down yet but it wont be long. I went with the 3.73 its perfect with the .75 od and 26" tires. 2500@70 mph.
slowcamaro
03-19-2007, 05:26 PM
torsen t2r?
molyorange 77
03-20-2007, 05:28 AM
Detroit TrueTrac
chevella
03-22-2007, 05:52 AM
Molyorange, how does the true track behave? Correct me if I am wrong, but aren't it and the Thorsen somewhat the same type of design. The reason why I am asking is I put a Thorsen in my daily driver a year or so ago and it worked great at first, but recently it has become unpredictable. Like if you gas it hard in a corner, sometimes only the inside wheel will pull. There may be a problem with mine, as it has got a bunch of miles on it. Any case I will be in the market for a posi unit in the near future for the Chevelle and I was also considering the true track. Keep me posted once you put some miles on it.
