View Full Version : Project "BAD MAV"
aussiebj
01-27-2007, 01:16 PM
This thread will follow my 1970, 460 powered pro touring maverick ,so far i have inatalled a mustang two front end the 460 motor and c6 transmission is mocked up engine mounts are made, i have not yet decided if i will stay with the auto or change to a 5 speed ???? the motor as it sits puts out 600 hp and 545 ft lbs of touque it is however going to be freshend up when i pull it out to finish and paint the engine bay i will swap to aluminium heads for weight savings...the rear end is a ford 9 inch with 4.11 gears as of now..here are some pics
aussiebj
01-27-2007, 01:25 PM
Just finished installing my brake booster i had to move it over 3 inches to make room for a booster and so i can remove the valve cover...
aussiebj
01-27-2007, 01:37 PM
here are pics of the mav and the booster install
aussiebj
01-27-2007, 01:50 PM
The wheels on the car in the pic are american racing Hopsters 15 x 6 on front and 16x 8 on rear, i picked up my new rims custom made Hopsters 17x 11 with a 4 and 1/4 inch back space, tyres are 315x 35x17 for the rear, i will be mini tubbing it and after searching the archives here in this web i am going to install a triangulated 4 link with coil overs .
71dusterdan
01-27-2007, 02:34 PM
aussie, i love mavericks,would build one after my duster if i could find a decent one. I do have to ask at the risk of offending you, why would you drop a big block in a maverick and then think it will corner and stop. that is alot of weight on the front end , i would believe it will be an understeering S.O.B. Do not get me wrong your car is cool and i love mavericks, i'm not beating you up, just cant see it turning. I would think i well sorted smallblock would run away from it everywhere but a straight line or dragstrip. just my .02 good luck and build away brother. Dan
aussiebj
01-27-2007, 04:24 PM
Dan i know of a guy who weighed a 351w and compared it to a 460 bb with aluminium heads and intake it only weighed 17lbs more and as for turning if a camaro with a big block in it can carve up the corners i do not see why mine cant i am going to try and as for a BB ford i wanted the wow factor when you lift the hood .The car will only see street miles so i am not to worried but if they build a road course near me (Long Island NY) i will certianly try it out.Thanks Barry
Restomod
01-27-2007, 06:13 PM
Headers look fun!! Nice!!
aussiebj
01-28-2007, 07:28 AM
i know everybody loves pics and i see updates with big pics inserted how is this done i would love to post all the pics i have on the build instead of just one or two Thanks .Barry
novanutcase
01-28-2007, 08:04 AM
https://www.pro-touring.com/forum/showthread.php?t=26620
71dusterdan
01-28-2007, 10:06 AM
give her hell aussie, i would not want to meet you on a long straight away. I'll keep checking back , i love mavericks
aussiebj
01-28-2007, 04:35 PM
aussiebj
01-28-2007, 04:37 PM
here is a pic of the mustang 2 front end install
aussiebj
01-28-2007, 04:39 PM
aussiebj
01-28-2007, 04:42 PM
aussiebj
01-28-2007, 04:43 PM
aussiebj
aussiebj
01-28-2007, 04:44 PM
aussiebj
01-28-2007, 04:56 PM
71dusterdan
01-28-2007, 05:39 PM
sweet, looks like some fine welding aussie. those headers had to be a sob
novanutcase
01-28-2007, 06:01 PM
Looks like the link worked!!!:)
You know you can add more than one pic into each post right?
John
aussiebj
01-28-2007, 06:38 PM
thank you John i am having fun, it is so much better to look at pics like this, i hope everyone does it i love this web site and all the forums,and thanks for all the input ..Barry
aussiebj
01-28-2007, 06:40 PM
Duster dan that was the easy side wait for the drivers side i am going to try and make them look some what the same....
aussiebj
01-28-2007, 08:22 PM
I have a question i hope someone can answer if i stay with an automatic does ford make a overdrive transmission that would handle up to 700hp and 600 ft lbs of torque...other wise i might have to run a gear venders overdrive unit and it costs $2800.00 alone.....
aussiebj
01-29-2007, 01:07 PM
the mav gets 315`s
nbecker
01-29-2007, 01:42 PM
315s on a maverick now were talking..the header does look pretty good,keep the pics coming
novanutcase
01-29-2007, 06:35 PM
I use to own a maverick when I was 17. I wish I would have kept it. AWESOME project!!:cool:
LMDGUY
01-29-2007, 06:40 PM
DAMN!! 315's .. looks like they might rub the fender??
aussiebj
01-29-2007, 06:52 PM
Yes right now they are rubbing on the fender but i just had to see what it would look like they will move in about 1 1/2 inches when i mini tub it and move up in the wheel well a bit ......
Blue70
01-31-2007, 04:18 AM
That is awesome!!!!
Very nice! :)
bnickel
02-11-2007, 03:03 PM
these guys can build an AOD that will live behind a 1400hp engine so i'm guessing they could build you one for the 460 with no problem at all. they also have bellhousing to adapt the AOD to the 460 as well
http://www.lentechautomotive.com/
streetrod77
05-08-2007, 10:44 AM
Nice project, I need you to write me a build book for your car. I need to read & learn more from you. That would include welding. I new I could fit a 315 on the back of my car. My backspacing must not be right. I have 295's & I also had to get a mini tube to fit them. The 460 is a very WTF factor.
David Sloan
05-08-2007, 11:00 AM
Cool Project!!
We are doing one for Comet Chicks dad that will fit 335's on the back, relocated the rear frame rails in about 4"s on each side.
Keep us posted.
LMDGUY
05-08-2007, 01:01 PM
Cool Project!!
Keep us posted.
Did you guys just make your own rear frame? Im about to start doin this to my falcon, just lookin for different ideas.
David Sloan
05-08-2007, 01:36 PM
No we used the stock frame rails cut them loose from the inner wheel tub an the trunk floor on both sides then moved them in about 4" cut about 8" out of the center of the trunk pan welded it back together.
Then you pick your rear suspension, cut the rear end to the desired length.
Hope this helps
aussiebj
05-09-2007, 02:09 AM
I have enough room to just cut the inner wheel house back to the frame rail, and if i wanted i could reuse my leaf springs but i am going with an Art Morrison triangulated 4 link set up..
aussiebj
05-09-2007, 02:11 AM
streetrod 77 when i am finished i could put a photo dvd together for you with all the detailed pics if you want.......
streetrod77
05-09-2007, 11:04 AM
That would be great. I will look for that when you get around to it. I want to go with 335's now since I know it can be down. I really need to learn how to weld before I tackle a job that big. I had to pay someone to do the mini tubing for me & it didn't look hard but I cant weld so I couldn't do it. Thanks for the helping hand.
LMDGUY
05-09-2007, 09:42 PM
Hope this helps
cool.. any pics?
aussiebj
05-12-2007, 06:58 PM
I have decided to sell all my projects to spend more time with the family ..see 4 sale section...thanks for all the help Barry
LMDGUY
05-13-2007, 12:00 PM
:crying:
aussiebj
10-18-2011, 05:41 AM
Dont worry I bought another mav its called Bad Mav 2 check out the project section..this one will be a nice pro tourer..Mavs rule...
https://www.pro-touring.com/showthread.php?75139-Project-Bad-Mav-2-Styreet-Track-car&highlight=maverick
