View Full Version : OK I am confused & stupid, what is smaller: 40 microns or 100 microns?
Samckitt
01-20-2007, 08:24 AM
:help!:
brn agn
01-20-2007, 09:29 AM
40 microns=.040 mm
100 microns=.100 mm
40 < 100
Tucks69
01-20-2007, 09:33 AM
40 microns is a smaller particle than a 100 micron particle. Usually as the micron size gets smaller the amount of particles per million goes up. That is how I read my lube oil samples at work. If you are talking filters anything 40 and above will be trapped in the media.
Mike
Samckitt
01-20-2007, 12:40 PM
Then why is a 40 micron billet summit filter about half the price as a 100 micron filter? Seems to me like it would be the other way around. Would 40 micron be OK for fuel injected?
camcojb
01-20-2007, 12:47 PM
100 micron is generally used for a pre-filter in front of the pump. Most filters after the pump are in the 10-40 micron range.
Jody
Samckitt
01-20-2007, 06:23 PM
My pump is in the tank. It is a factory Buick GN setup. So I will just get the Summit 40 micron in line unit.
Thanks.
