Mathius
01-16-2007, 01:59 PM
I want to extend my rockers so that they hang down so that I won't be able to see my frame rails in the side profile anymore. I'd also like to run a side exit exhaust, so I was going to run it through the new rocker panel I created...
My question, is what is the best way to mount it? It will have to be rigid mounted to the rocker, will this cause problems with not having enough travel in the exhaust? (isn't this why most exhaust mounts have rubber hangers?)
Also, will this hurt my paint? (heat disappation) I've seen some guys use aluminum trim on the inside of the cutout. Does this help keep the heat down?
Mathius
Mathius
