View Full Version : Will AFX spindles work with C6 ZO6 brakes?
CamaroJesse
01-04-2007, 09:14 PM
i did a search but couldnt find anyitng. im wondering if the AFX spindles from touring specialties will work with the C6 Zo6 brake set up.
thanks
Jesse
Stu Seitz
01-04-2007, 09:25 PM
yes
jfman
01-04-2007, 10:30 PM
yes
yes, bolts on straight up.
Stoker420
01-21-2007, 10:24 PM
do you need brackets and what about those bigger hotter rotors will the afx spindels work with those rotors?
http://www.kore3.com/proddetail.php?prod=10151-01
jfman
01-22-2007, 05:26 AM
No you should not. Basicaly it's the same as if you were putting C6 z06 brakes on a c5 corvette.
Dont trust us...
Just go there and ask these guyz
http://forums.corvetteforum.com/forumdisplay.php?f=1
Lots of c5 peeps instaling c6 zo6 calipers and rotors
Basicaly wehn you own AFX spindles, think c5 corvette for brakes. Anything made to fit a c5 corvette will fit the AFX.
chicane67
01-22-2007, 11:29 AM
Uhm...
...anything C5 or C6 will fit the AFX spindle. You dont have to think C5 for specifically anything.
hectore3
01-22-2007, 11:46 AM
How about the aftermarket application of pad choices for the C-6 Z06 6 piston caliper? For both street,autocross and HPDE.
Stoker420
01-22-2007, 01:22 PM
Ok is there a left and right rotor on the c6 z06 setup or are they the sme part# for left and right?
chicane67
01-22-2007, 01:41 PM
I know that HAWK now has three compounds available for the C6/Z06 caliper. Other than that, I havent really seen anything mainstream from other manufacturers.
Although, I am sure if you had a set of pad backingplates that Porterfield can/would re-line them with their offerings. Their R4-S compound would be an excellent choice.
I believe that they are still the same.
Madspeed
01-22-2007, 02:07 PM
Stroker your answer is Printed in the very link you posted
check your link I did and found it increadably usefull
BTW good find nice price on a complete brake setup for the AFX system im installing on a 65 ElCo
72SSAbody
01-22-2007, 03:58 PM
Give Gene at www.GMpartshouse.com a call or E-mail.
They have the best prices I've found on GM parts and Gene has been a very helpful guy in the past.
Joe
jasonsnova
01-23-2007, 07:13 AM
ok so if i have afx spindles already, cant i just pick up some c5 or c6 rotors and calipers on ebay and everything should bolt up right??.....sounds like the cheap way+ up gradeing suspension geometry right?
jasonsnova
01-23-2007, 07:33 AM
also whats the difference between the c5 and c6 set ups??
jfman
01-23-2007, 09:40 AM
I bought c5 rotors and pads at Oreily. (brand is Wagner)
$51 for each rotor and $29 for the pads.
The calipers and brackets I bought used on the the corvette forum.
Heres a guiy selling a pair for $150 as well.
http://forums.corvetteforum.com/showthread.php?t=1587579
Stoker420
01-23-2007, 01:14 PM
Madspeed I found cheeper stuff at http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=C6
jfman
01-23-2007, 02:27 PM
Do you know how much they charge for shipping ?:jawdrop:
Madspeed
01-23-2007, 02:53 PM
did you ctually calculate all the necc components? incl hoses bolts and other hardware
and shipping?
I think youl find GMPD shipping a Ripoff =0
But another good find =)
Stoker420
01-23-2007, 02:59 PM
no I didn't do the shipping check opps sorry
Madspeed
01-23-2007, 03:08 PM
Dont trust us...
I just got off the phone w Tyler at ATS. Its official the zo6 brakes fit the afx spindals
Stoker420
01-23-2007, 03:48 PM
I did that yesterday :hah: I also talked with the dude over at KORE3 and they have other rotors and they may be getting aftermarket pads for them.
