malibujason79
01-03-2007, 06:21 PM
I posted this on msd's web site and haven't had a reply yet. Anyone want to give there two cents? thanks jason
I'm working on my 400 sbc and i have a couple questions. My ignition set-up is 8360 distributor, blaster 2 coil, 6al, and 8.5 wires. When i put the engine together i installed the distributor just as it comes from the factory with the 2 heavy silver springs and blue 21 degree bushing. i started the motor brought it up to 3000 rpm and set the timing at 36 degrees. Well what i guess i didn't understand, was that with the factory distributor set-up at 3000 rpm the advance was only 15 degrees and not the 21 degrees, so my total timing was 42 degrees at 4000 rpm.
So this past weekend i installed the black 18 degree bushing, one heavy silver and light silver spring, then set my timing to 36 degrees at 3000 rpm. i also removed the vacuum advance since my cam doesn't give much vacuum. When starting the car cold, i will get a small backfire out of the carb. Could this be caused by a lean or rich condition since ive changed the timing. Also ive tried to check my base timing at idle with a plain jane craftsman timing light and a craftsman dial ( which i know you shouldn't use a dial with this set-up) and at idle i'm showing 23 degrees. Is this something to do with both timing lights? or is my timing curve coming in at idle?
