View Full Version : Aftermarket steering arms - Somebody should step up
Boulder69
01-03-2007, 01:06 PM
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=015&sspagename=STRK%3AMEBI%3AIT&viewitem=&item=250066861096&rd=1,1
This is ridiculous! I have been trying to win some of these for months. Somebody please make some aftermarket short steering arms for 1st Gens.
ATS, you make 'em for the A bodies, make 'em for the F bodies PLEASE!
Anyone out there know of a source? Thanks. -eric
130fe
01-03-2007, 05:15 PM
Eric, I know what you mean. I lucked out a couple of months ago and found a set for only $125 (buy it now) :screwy: on there. I ended up calling most of the national used parts houses and noone had any. It is amazing the price between the short ones and the others (Long, med). Maybe someone on this board might have an extra set.
BonzoHansen
01-03-2007, 06:51 PM
What are there, 3 different ones?
I don't know what ones are on my 67 w/MS, but I have a set of 3902517/8 off a 67 w/PS in my garage right now. What are these?
MuscleRodz
01-03-2007, 09:08 PM
I think there may be 4 if you count Pontiac. I will check and see what I have.
Mike
Boulder69
01-05-2007, 03:06 PM
Mike,
Did you have a chance to find anything? I grew up in OK if that helps........
dropit69
01-05-2007, 03:48 PM
im parting out a 70 pontiac tempest..not sure which one it has but will sell if someone needs it..
130fe
01-05-2007, 06:24 PM
Check out David Pozzi's suspension website: http://www.pozziracing.com/camaro_steering.htm#Steering_linkage Scroll about 2/3 the way down and you willl see them and their part #'s. His suspension site www.pozziracing.com (http://www.pozziracing.com) is one of the best around for this sort of stuff. Good luck!
MuscleRodz
01-05-2007, 10:15 PM
I think I have a pair on either my 69 bird project or off my Camaro. I still need to verify part numbers though.
Mike
MuscleRodz
01-06-2007, 03:06 PM
I checked and they are not quick ratio arms. Sorry.
Mike
BonzoHansen
01-06-2007, 08:29 PM
Check out David Pozzi's suspension website: http://www.pozziracing.com/camaro_steering.htm#Steering_linkage Scroll about 2/3 the way down and you willl see them and their part #'s. His suspension site www.pozziracing.com (http://www.pozziracing.com) is one of the best around for this sort of stuff. Good luck!I forgot he had that stuff there.
Hmm, the one I have sitting here right now came from a 67 P/S car, but his site says:
LONG 6" manual, - LH-3902517 RH-3902518 (67, early long measured at 6") LH-3917193 RH-3917194 slow ratio manual steering.
I had no reason to believe they were changed, but I guess something was changed. Maybe P/S was added later.
130fe
01-07-2007, 08:24 AM
Eric, you have PM.
Mr.VENGEANCE
01-07-2007, 08:52 AM
im stupid, whats the benefit of these?
paul67
01-07-2007, 09:35 AM
I had a set of 17" rims and the short 1s were the only 1 that fitted.
pav8427
01-09-2007, 08:31 PM
Thought you guys might be interested. Just ran across HOT ROD Sept 2002 with Kevin Kings(Year One) orange and white rag top 69 w/LS1.
Check page 25 and look at the nice billet? steering arms made by
Brewers Restoration and Performance. They switch it to front steer, but I wonder if they can be flipped?
Doug
01-10-2007, 12:40 AM
no there are made specifically for that set up. I have a bunch in storage, I will see what I have.
Leadfoot1
01-10-2007, 05:08 AM
It always gets interesting here doesn't it?
:twothumbs
Lead.
killer69
01-10-2007, 08:16 AM
If you contact Unisteer they may sell you a set as there rack and pinion setup comes with them. they do drop the tir rod end down a slight amount to help the bump steer with the rack. don't know what the effect would be with stock steering?
MarkM66
01-10-2007, 08:57 AM
If you want to run a front wheel with more then 5.25" of bs, you need these. I know this is true with a 17", I never tried it with an 18" or larger.
