View Full Version : Air Ride Questions
BRIAN
01-01-2007, 09:04 PM
Not looking for an; "If it works debate".
How accurate is preset height. What I mean is if you set a determined height how close is this height kept? Any change after use? I know there are a couple different ways to set this so I guess please list what you are using if you have any experience.
Is there a sag to the bags? I know it can be compensated for with addtl pressure??
I appreciate the help.
formula
01-01-2007, 11:35 PM
kept as in inflated to the preset, deflated, and reinflated to the preset, or kept as in maintained after inflation?
jb@ridetech
01-04-2007, 06:52 AM
Preset ride height can be very accurate, depending on the system, we offer 2 systems, the ridepro e2 kit use sending units to measure air pressure, this system works good, but if you are looking for something that is a true leveling kit use our Levelpro system its uses the sending units to measure pressure and a sensor at each wheel to achieve a perfect height every time, even if you add a few people and luggage.
