View Full Version : Spindle Seal????
dhardison
11-25-2004, 07:36 PM
I was cleaning my spindles this evening in prep for drum->disc conversion and noticed a 'seal' that goes on prior to the hub. In the pic below it was located in the area designated in red. I've also attached a pic of the 'seals' I pulled off.
They're made out of some sort of gasket material, not metal. I was almost ready to reinstall the hubs and now I don't know if these need to be replaced or if they're even needed at all.
-Has anyone ever come across these on their car?
-What are their purpose?
-Do I need to replace them? If so, what are they called and where can I find them?
https://static1.pt-content.com/images/pt/2004/11/spindle-1.jpg
https://static1.pt-content.com/images/pt/2004/11/spindle_seal-1.jpg
Dan
dennis68
11-25-2004, 08:15 PM
Throw them away. Not nesessary, kind of an extra dust seal. You have to remember what kind of seals that GM used to use during the 70's-80's. Most newer seals are twin lip seals with the lips facing away from each other. One for grease retention and the other for dust/debris/element barrier.
dhardison
11-26-2004, 05:59 AM
Thanks Denny!
Dan
