b-man
12-27-2006, 01:55 PM
Just thought I'd throw my hat into the ring and join your site. Here's a few pics and details on my very understated 1964 Tempest Pro-Touring car.
Rolling stock consists of 17X8" custom-made black-painted steel wheels (zero offset) running factory Pontiac dog-dish caps. Tires are 235/45-17 all around, will be going one size bigger the next time I need tires (245/45). A 1/4" wide red stripe was painted on the rim lip to simulate the look of a factory 14" redline tire, fools a lot of people until they look a little closer.
Up front are '78 B-body (Bonneville wagon) spindles & 12" rotors re-drilled for A-body 5 on 4.75" bolt circle, along with Hotchkis tubular upper A-arms and HO Racing front springs. The factory lower A-arms have been reinforced with plates welded in the lower bushing area.
HO Racing 1-3/8" front & rear sway bars were installed, along with owner boxed rear lower control arms and new stock regular-ride rear springs cut down by 3/4 of a coil. Urethane bushings and KYB gas shocks are installed all around.
A quick-ratio high-effort 12.7:1 power steering box and pump by Lee Power Steering upgrade the steering, I kept the big stock steering wheel. This car has non-power manual brakes, the stock 9-1/2" rear drum brakes were retained.
Power was provided by a +.030 '73 455 with '66 Tri-Power induction, 068 cam/1.65 RAIV rocker arms, stock '71 455 #66 heads (8.2:1 comp), reproduction '67 RA/HO exhaust manifolds. A column-shifted TH400/13" Continental converter/2.56 open rear complete the drivetrain. Ran 13.899 at 101.85 MPH on 87 octane, shifting into 3rd after the finish line. The Tempest has a 140 MPH top end, the stock 2.56 gears were great on my highway commute while driving to my old job 40 miles away.
The Tempest started out with a factory (standard equipment) 215-cube 140HP six cylinder and a Super Turbine 300 2-speed auto, ran 20-second 1/4 miles at nearly 70 MPH. Smooooth and quiet, good gas mileage (20 MPG).
I built this car to be a stealthy street warrior, looks like a stock mid-'60s econo sedan. Column shift, no tach, bench seat. Not an expensive build by any means, but plenty of bang for the buck.
Fun to drive, handles so well I can scare myself.:drive1:
https://static1.pt-content.com/images/pt/2006/12/DSC00839-1.jpg
https://static1.pt-content.com/images/pt/2006/12/DSC00842-1.jpg
https://static1.pt-content.com/images/pt/2006/12/DSC00845-1.jpg
https://static1.pt-content.com/images/pt/2006/12/DSC00846-1.jpg
https://static1.pt-content.com/images/pt/2006/12/DSC00848-1.jpg
