View Full Version : Help Needed
68Camaro
12-26-2006, 12:00 AM
Hey guys, hope yall all had a merry Christmas.
I need some questions answered if possible.
I'm converting to manual brakes(car: 68 Camaro) and ordered new pre-bent lines. Problem is some of the lines don't match up. I'm reusing the distribution block, its bracket and the POWER master cyclinder. I wanted to mock it up and get the system bleed and then figure out which MC I needed.
So here are my ?????
1. Is there a difference in the port locations in POWER and MANUAL MCs?
2.Are the distribution blocks different? Bracket for it different?
I need to get the car back on the road for school/work.
Thanks for the help.
Jared
Tucks69
12-26-2006, 08:16 AM
Hey Jared
I sent you a PM. I have pics of my stock 68 camaro setup. The pics are to big to post here.
Mike
68Camaro
12-26-2006, 11:05 AM
Thanks Mike, I sent you my email.
Does anyboyd else have any info?
BA.
12-26-2006, 01:34 PM
I'm almost 100% certain that the distribution block is different. I upgraded my power drums and I believe I recall that much.
Not sure about the brackets. (I've tossed the old stuff)
I don't think I know what you mean by "port location" for your first question. I'm brain dead!
68Camaro
12-26-2006, 07:26 PM
By port location, I mean the location of where the 2 lines exit the MC. Are they in different locations in a POWER and MANUAL MC?
68Camaro
12-29-2006, 05:20 PM
Thanks Mike for the pics!
And for future inquiries:
1. The only real differences between a MANUAL and POWER MC is that a power MC will have a larger bore diameter than a manual MC. And a manual MC will have a deep piston hole to accept the manual brake push rod while a power MC will normally have a shallow hole.
2. The bracket is the same as well as the distribution block.
My lines were a little tight and just needed a little muscle to make fit. Some needed to be reshaped; don't know if this is common b/c my setup is not 100% stock.
