View Full Version : Anyone Running 79 TA Rear Disc on a 2nd Gen Camaro?
tomspo04
12-25-2006, 05:49 PM
If so, would you please help me figure out the parking brake cable requirement? I've got the rear discs hooked up and working fine...I've installled 79 TA rear parking brake cables coming off of the calipers...is there a cable (like the Camaro) that runs across the two rear cables? If so, where do I get one? Thanks...in advance.
Tom
Skip Fix
12-26-2006, 03:18 PM
They should clip right in to the cable for the drum rear parking brake. They just take a different length cables from the calipers to the connector vs the drum cables.
tomspo04
12-27-2006, 11:19 AM
Thanks, I'll try... Guess I should've kept the old stuff when I tore the car apart!:confused: :eek:
Skip Fix
12-27-2006, 07:42 PM
Cable from the pedal has a 7/16 nut(I think) that pulls on a slightly U shaped piece the individual cables slide into, whether drum or 4WD. More on the drivers side. Passenger side slides on exhaust pipe some to get there.
