View Full Version : Paint mixing questions
Project69
12-23-2006, 08:32 PM
Well ive prepped my car for paint but im not sure how to mix the paint, ive never painted a car before so mixing it is gonna be the hardest part haha. Any ideas on instructions would be helpful. Oh and im using a Dupont Super Black single stage with the reducer.
customshop
12-23-2006, 08:45 PM
Most all of the cans have the mix ratios on the can. make sure if you dont have that you acll how ever you got the paint from as it is very important you mix correctly. Spray with an even overlap of about 50% dont go to slow or you will have runs. hang a peice of paper up on the wall and spray a little bit on that it will waste a little paint but better then sanding all of your work down. good luck. you can see some of my paint work at . www.customshop.org (http://www.customshop.org)
ProTouring442
12-24-2006, 04:08 AM
Another thing you may want to buy the Dupont Manual, or at least ask for the info page for your paint. Lots of good info there.
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442 (http://www.FQuick.com/ProTouring442)
KMD
12-24-2006, 08:28 AM
If the single stage is ChromaPremier single stage here is the tech sheet. The super jet black in ChromaPremier is G9900N
http://www.performancecoatings.dupont.com/dpc/en/us/html/prodinfo/chromasystem/H-19311_CPUreSS.pdf
Also, here is the DuPont link, all tech sheets are here.
www.performancecoatings.dupont.com (http://www.performancecoatings.dupont.com)
