Jeremy
12-22-2006, 05:49 PM
I need a new rag joint and was wondering if there was something that works better. I have no problem with a new rag joint, but I wanted to make sure that there has not been something produced that is better.
pontiacbird
12-24-2006, 01:04 PM
I would like to know the same thing as you, because the rag joint can cause some lack of precision of the driving. On my car, I made two couplings from a 1/4 inch pipe nipple and I manually pressed fit them on the security pins of the rag joint. It considerably reduces the possibility of distortion of the rubber.
VERY IMPORTANT ; If you want to try it, make sure there's no bending while turning the rag joint.
Here is a picture of my installation
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us)
69TAPoser
12-24-2006, 01:35 PM
Go here:
http://www.flamingriver.com/index.cfm/page/ptype=results/category_id=76/home_id=82/mode=cat/cat76.htm
Phil
