View Full Version : tick tick a-tick tick
harshman
11-24-2004, 11:01 AM
I just finished installing Comp cams 213-3 complete kit. On cylinder #2 exhaust there is a definite “tick” noise coming from the lifter. I swapped lifters and the noise remained. I contacted Comp cams tech help and they gave me the “I don’t know what it is” answer. I got a “it might be a bad lifter” at the most. What do you all think? Most everybody said to put 500 miles on it and reevaluate the noise.
zbugger
11-24-2004, 11:56 AM
Have you checked for an exhaust leak? How about the intake gasket? Those are very common. Also, take a look at the pushrod and rocker. Just make sure you get every possible angle on it.
harshman
11-24-2004, 12:00 PM
yup, i checked out the pushrod and rocker. i put my stethascope (sp) thingy on the adjusting nut and found the noise. it doesn't start untill about 5-10 seconds after startup which would tell me hydraulics.
