View Full Version : C6 Z06 rears on a 9"
Chris442
12-20-2006, 12:17 PM
I know that this is possible, but I can't find the brackets that I need to make it work. I'd like to use the drum parking brake too if that is possible. Does anyone know who would have these brackets?
Oh yeah, it's a big ford bearing hub.
smeshey
12-20-2006, 03:06 PM
not sure if this will help but for my 98 Z28 I had a local rearend guy cut the for flanges off and install new gm flanges. This allowed all my brackets and everything to bolt right on. He is REAR GEARS in Missouri his name is danny miller. If that helps at all
triplecap
01-05-2007, 12:37 AM
Check out Kore3 at http://kore3.com - I talked to Tobin there last week and he had all the brackets for C5 & C6 (Z06 too) on a ford rear.
Eric
TTOP350
01-05-2007, 06:35 AM
You can use a stock F-body park-brake setup just redrill the 4 holes and have the center opened up to a little bigger than the for bearing so you can slide the axle in and out.. I have done this but its hard for me to explain exactly how.
