View Full Version : Project GBodyGMachine UPDATE *pics*
GBodyGMachine
12-14-2006, 01:14 PM
Ok, It is going slow. But now that I have the car at the shop I work at things should pick up. Here are a few pics of how the frame is going. I hope to have the rear suspension done by the end of this week.
https://static1.pt-content.com/images/pt/2006/12/Progress005-1.jpg
https://static1.pt-content.com/images/pt/2006/12/Progress008-1.jpg
https://static1.pt-content.com/images/pt/2006/12/Progress001-1.jpg
https://static1.pt-content.com/images/pt/2006/12/Progress011-1.jpg
Jeff
redss86
12-14-2006, 03:05 PM
Nice work. Man, that pic of the frame from the rear really shows how there is no torsional resistance in our gbody frames(i.e. no permenant crossmembers). Looks like it will be a fun car when its done.
What, size rear tires are those?
Joe
GBodyGMachine
12-14-2006, 04:50 PM
I actually cut out the old spring perchs to make way for the coilover setup. I will have alot of cross-member in there shortly. And I will hopefully be running a 295/35/18.
Jeff
s10kool
12-14-2006, 06:36 PM
i wanted to do a set up like that with my 87 trubo t but i had to sell it
SicMonte
12-14-2006, 07:14 PM
295/35/18?? sounds good to me bro. what wheel width and bs are you gonna run? im selling my 17x11's b/c they stick out just a lil bit...but its enough to piss me off.
SicMonte
12-14-2006, 07:15 PM
one more thing..are you gonna run a cage in yours??
GBodyGMachine
12-15-2006, 03:56 AM
I would run 11's but the rear tires are going to tuck, so I have to run 10's with a 5" BS to be safe.
I am thinking about caging it just to add some strength to the frame. But I am not that far in the project yet. For now I am concentrating on the chassis.
JEff
GBodyGMachine
12-16-2006, 09:13 AM
Started setting up the rear coilover setup today, I didnt have alot time but I got one crossmember welded in. Pics to come.
Jeff
SicMonte
12-16-2006, 11:12 AM
i love it!!! seeing the progress really motivates me!!! did you just do the frame notch or did you do a mini tub as well??
update: i sold my rims b/c the rears didnt fit right. they were 17x11 with 5.5 b/s....stuck out just a tab on my driver side.....so now im in the market for some new ones. i will be in touch!!!
GBodyGMachine
12-16-2006, 11:39 AM
I dont know if I need to mini tub yet. I would guess I will have to because the car will be so low. But that comes ofter the body is back in the frame.
Jeff
GBodyGMachine
12-17-2006, 05:23 PM
Common G-Body guys, Feedback.
Jeff
Bandit
12-17-2006, 05:36 PM
Good deal Jeff, looks like it's coming along. (Those QA1 coilovers are hot!) Just so you know I am following your project so you better stick with it!
BTW did you ever decide on a "project name?"
Paul
brrymnvette
12-20-2006, 12:06 PM
Why don't you notch that frame right now while the body is off. Get yourself and extra 2" for the rear tires. I'd do it now if I was you. You'll be doing it later and wish you did it now. Did I mention do the notch now? :)
GBodyGMachine
12-20-2006, 01:36 PM
I did, cant u tell by the pics?
Jeff
brrymnvette
12-20-2006, 01:41 PM
I couldn't until you metioned it. I saw part of the frame rail and it looked like you hadn't. I see now you did it to the seam like most do.
87SS
12-23-2006, 09:08 PM
looking good, keep up on the project:)
