View Full Version : Aluminun Radiators ?
dmastrota
12-12-2006, 07:32 PM
Whats the best aluminum radiator set up most are using to fit 1967 Camaro/ Firebird?
dmastrota
12-22-2006, 04:16 PM
Help please!!! Nobody has any suggestions. Any recommendations would be appreciated. I am probably leaning to R Davis.
ProBell
12-22-2006, 06:00 PM
I used a factory radiator and fans out of the 99 Camaro. Works good for me with the ls1.
John McIntire
12-22-2006, 08:14 PM
do a search, this topic has been pretty well covered. You'll find that most will recommend Be Cool or Ron Davis. I've had both and would lean toward the Ron Davis if its in your budget.
gmachinz
12-22-2006, 11:30 PM
Check your mail. We build them with HD Mark VIII fans and Spal PWM controllers installed also! A nice radiator alone won't shed much heat. You need to figure out how you want to pull the heat out, and for that, nothing beats a Mark VIII fan!
Cyclone
12-23-2006, 12:59 PM
Did you get my PM?
PT_79_TA_461
01-18-2007, 08:11 PM
take a look at jegs and summit mail order parts, thay have rads made by becool and griffin, thay also have universal fit rads that are not to expensive, but if your running a modded engien, the stock rad might not keap up with the cooling demandes of your motor, it all depends of what you do with the cars and if the motor is modded or not, i got a pontiac 461 stroker and the stock rad didn't even do the job, i would have to pull over alot to let it cool a lil, i put in an aluminum rad by becool and now its great, no more overheating.
6'9"Witha69
01-19-2007, 09:15 AM
I suggest AFCO!
