Results 1 to 7 of 7
Thread: need brake help on 69 Camaro
12-02-2006 #1
- Join Date
- Mar 2006
- Location
- Dayton, Ohio
- Posts
- 72
My 69 Camaro started out all drum and manual brakes. First I installed a front disc conversion kit. Same m/c set up and had no problems. I just installed a rear conversion system from ABS power brakes and a chrome m/c and purportioning valve. I can pump the pedal up, but 20 sec. later straight to the floor. No leaks at all and we thought the m/c was bleeding off internally, so we put the stock one back on and same problem. We even tried taking the purportioning valve out and running straight off the master. Still it did the same. With the car off the ground we have enought pedal at the bottom to stop the wheels. One of my friends said I needed a 60's style master cyl. from a corvette to push more volume. I need help with this one. Also I'm keeping it manual and not going power right now. Please someone give me the answers.
