View Full Version : Dull rear light lens
paul67
12-02-2006, 11:58 AM
What can be used to put the sparkle back into lens ,mine are 1st gen camaro.
BonzoHansen
12-02-2006, 12:29 PM
I don't know if this correlates, but the headlights & turn signal lenses on my 93 K1500 were beat up pretty bad. I just took some 3M rubbing compound to them and they cleaned up pretty well.
Jim Nilsen
12-03-2006, 03:42 AM
3M makes a plastic cleaner and plastic polish for len's. Go to 3M.com and you will find it. Otherwise you can use regular polishing compounds and it will make a big improvement.
TPI Monte SS
12-03-2006, 10:40 AM
I've actually wet-sanded lenses with 1500grit, then used 3M rubbing compound by hand (no electric buffer), followed by Mother's Plastic Polish. Came out great!
69TAPoser
12-03-2006, 10:54 AM
You could always switch them to LEDs! :)
http://www.americanautowire.com/products/LED_Sequential_Tail_Lights.cfm
Phil
paul67
12-04-2006, 11:47 AM
I intended to switch to the l.e.ds but you need lens don't you , does anybody do flush 67 light rims and lens
TonyL
12-04-2006, 12:34 PM
Wet sanding and polishing works awesome. as does using a spray on clear.
the clear coat will outlast Mother's polish by about a year, I've learned.
vanzuuk1
12-04-2006, 02:02 PM
Once you have them buffed out pledge works great also
