View Full Version : Replacing just one tire?
formula
11-30-2006, 05:55 PM
As many of you know, I had a tire blow out on my bird about a week ago. The rest are somewhere around 3 years old but still decent on tread, as the car's been down for rebuilding for at least 6 months and is usually only driven a couple times a month. Would it be safe and mechanically ok to replace just the right front tire? Or should I at least get two new front ones?
6'9"Witha69
12-01-2006, 09:32 AM
Usually you replace one axle at a time unless the other front is like brand new. I would do 2 new fronts.
TonyL
12-01-2006, 09:41 AM
replace both. Why did the tire blow out in the first place?
I've seen tires blow from cracking from sitting. Just something to think about.
larknut
12-07-2006, 09:32 AM
I would replace both.
Here's a senerio, let's say your remaining front tire has 75% of its tread left and you end up replacing just the one. That older, more worn tire will spin faster than the new one due to having less overall rolling circumfrence. This could quite possably result in a pull to one side (the worn side).
BonzoHansen
12-07-2006, 10:02 AM
If a tire is cracking in 3 years, take them back for warranty replacement.
IMO, it very much depends on the wear of the other tires. For a performance application, I'd say if it is more than 2/32" difference, I'd do both.
