View Full Version : Drag Touring enhancements....
Nine Ball
11-20-2004, 03:37 PM
Sure, its a "Pro-Touring" car, but with a simple wheel and tire swap, and the addition of a new 6-point rollbar, it sure does look different. I had to reposition the rear shocks upwards a bit, and slightly grind some casting corners off of my fancy front brake calipers, but everything fits now.
28x10x15 Hoosier slicks
15x10 (5.5 backspace) Weld Pro-Stars in the rear
15x3.5 Weld Pro-Stars in the front
http://www.ls1tech.com/69Camaro/drag01.jpg
http://www.ls1tech.com/69Camaro/drag02.jpg
http://www.ls1tech.com/69Camaro/drag03.jpg
http://www.ls1tech.com/69Camaro/drag04.jpg
http://www.ls1tech.com/69Camaro/drag05.jpg
http://www.ls1tech.com/69Camaro/drag06.jpg
These are definitely the biggest tires you can fit under those stock quarters. I even had to roll the fender lips to make them fit!
Rollbar photos:
http://www.ls1tech.com/69Camaro/caged1.jpg
http://www.ls1tech.com/69Camaro/caged2.jpg
http://www.ls1tech.com/69Camaro/caged3.jpg
If the weather clears, and I get some time, I might hit the track tomorrow :3gears:
Tony
Ralph LoGrasso
11-20-2004, 03:56 PM
Lets see some ten second slips!
Steve Chryssos
11-20-2004, 04:01 PM
Tony,
Looks great. The suspension is still set up for handling? No changes (such as light front springs)
Nine Ball
11-20-2004, 04:04 PM
same suspension. I just loosen up the QA1 shocks alot up front, and those Cal-Trac bars on the rear work even with the car lowered.
If I can cut some 1.5 60' times, hopefully I can get a 10 second slip.
F70t/a
11-20-2004, 04:49 PM
What size brakes are you running tony?
Nine Ball
11-20-2004, 08:31 PM
13s up front, I believe the rears are 12s. The front rotors stay about an inch behind those skinny wheels, thats how come they fit. I had to grind the outer corners of the brake calipers down smooth though. I took my time and did those slowly and kept the sanded areas smooth, and repainted the sanded area red again.
11-21-2004, 09:43 AM
Hey Tony, just checking if you made it out. Love to see what times you will pull...what no wheelie bar?!?! don't break anything!
JamesJ
11-21-2004, 10:31 AM
No way he made it out, the weather here stinks!! Rain and Rain and more Rain
Nine Ball
11-21-2004, 11:58 AM
Its been raining about a week straight here. Today is probably the worst so far. I'm fairly certain the tracks will be rained out tonight.
This sucks! Maybe next weekend, unless a weather miracle happens.
my car is too slow for wheelie bars. What do you think this is, Pro-Street? :lmao:
Streetking
11-21-2004, 08:12 PM
Looks great Tony! The weather does suck, I have been trying to get to the track for 2 weeks!!
SW
DCx
11-23-2004, 01:25 AM
Those wheels are awesome! I have a 69 with standard wheel tubs and rolled fender lips. Do you have much room around the wheel well? How close are they to the shocks? I also have some cal tracs. I was thinking of getting some huge 15" tires until I can afford some 17" I pretty much want to track whore my car. The cage will be in soon.
Nine Ball
11-23-2004, 07:15 AM
with the proper offset wheels, I have about 3/8" between the sidewall and the stock inner wheel well. Now that I rolled the fender lips I have about 1/2" there between the sidewall and lip.
The tires clear the QA1 shocks by a large margin since the shock reservoir is located on the bottom side of the shock instead of the top.
Steve Chryssos
11-23-2004, 08:24 AM
I think the right magazine would kill to run a comparison tech piece on drag racing a pro-touring car. Inquiring minds wanna know:
-How did the wheels fit over big brakes?
Conversely, you can show how brake size may need to be limited if multiple wheels and tires are intended.
-Can the suspension be tuned quickly for improved E.T.?
Coil-over adjustment, sway bar disconnect, etc.
-How does the quarter mile performance compare?
Do a direct comparison: Same day, same track, different wheels/tires/tuning.
Please take lotsa pictures and submit the edit. You will help a lot of people.
Nine Ball
11-23-2004, 08:47 AM
Good idea Steve. I'll document everything and take some photos for my website too.
Any pro-touring cars out there with a wheels up launch photo yet? Maybe I can start that trend here. haha
JonB69FB
11-23-2004, 09:00 AM
I haven't run skinnies on the front of my car, but setting the front shocks full soft (rebound), disconnecting the front swaybar (I just remove the passenger's side end-link), and leaving the Cal-Tracs alone (basically set at no preload w/driver) has netted me several 1.5x 60' times on a 26x10" slick.
Good luck! Hope the weather cooperates. Around here it seems the only time I can get to the track is when it's hotter than the surface of the sun.
No wheels up launches but HPP got a couple of bitchin' burnout shots: http://www.firebirdofdoom.com/hpp_big.jpg
Edit: Oh yeah, the Cal-Tracs were definately the key to my combination. Consistent .100 drop in 60' time. I run my slicks at around 13.5psi w/tubes in case anyone cares.
Nine Ball
11-23-2004, 09:41 AM
Nice runs Jon! Your times/trap on that article reinforce my confidence that I can get that 10 slip with 122-123 minimum trap speeds. If I can cut a 1.5X I'm definitely in.
TUBED
11-23-2004, 09:46 PM
Tony what's the rearspacing on the 15" Weld's up front? Thanks
Nine Ball
11-24-2004, 12:18 PM
I'm pretty sure they only sell them in 15x3.5 with a 1.75 backspace. They only make one size 15x3.5, you just have to tell them your lug pattern.
