View Full Version : Making spot welds
DRJDVM's '69
11-27-2006, 01:47 PM
I'm pretty new to welding and this is my first panel replacement (trunk pan in this case), so please bear with me with a pretty basic question....
When doing your spot welds, how big of a hole do you typically drill in the "top" panel and how far apart do you typically make them ??
PhillipM
11-27-2006, 05:36 PM
I am by no means an expert and I'm sure others may disagree with me but I usually punch 1/8-1/4 in holes and space them about every 5 inches or so.
toxicz28
11-27-2006, 06:17 PM
I usually drill 1/4" or 5/16" holes. As for the spacing, usually about 6" apart.
mikey
11-27-2006, 09:49 PM
I would recommend about 2"-3" apart. The closer they are the stonger they are. If you look inside a door jamb you'll see what I mean. There are more welds closer together around the striker and hinge areas than above and below them. Always use 5/16" holes That is what ICAR and manufacturers recommend.
