View Full Version : Tire leaking at rim seal - how to fix
TheMonkey
11-25-2006, 02:50 PM
one of my cars with old rims & tires that look good but not sure how old, are leaking from the rim seal. can this be repaired? i was going to bring it by a shop. do they just clean the rim up? why would this happen?
it's doing this at only one spot of the wheel, not everywhere, and the other 3 are fine.
thx.
Hidro
11-25-2006, 03:05 PM
I had this problem before and took it to the tire shop.All they did was wire brush the rim where it seals.
Should be fine if you do this.
You didnt say if the rim was steel or aluminum.Im assuming you have a steel wheel.
TheMonkey
11-25-2006, 03:06 PM
yip, steel. thanks for the reply. good news.
larknut
11-30-2006, 10:10 AM
This is true assuming there are no bends in the lip. They may even use a little bead sealer to help the situation.
TheMonkey
11-30-2006, 10:31 AM
i got all fixed up last night. didn't ask them how they did it, just paid them $14. it's a super old wheel so it prob just had to have the surface cleaned up at the bead.
thanks.
ProTouring442
12-01-2006, 04:59 AM
For future reference: I used to run into this quite often when people brought in old rims and old tires. To fix it, I cleaned the rim then smeared the tire with a bit of grease. The grease softens the tire and helps it seal.
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442 (http://www.fquick.com/ProTouring442)
