View Full Version : C5 calipers to stock steel lines, what flex line?
crazyfireman
11-21-2006, 11:42 AM
I have everything i need now with the exception of the Banjo line on the caliper to the steel lines from where the old rubber line was. My question is can I use the C5 stock lines and have an adapter or something to connect it to the stock steel drum lines??
Mkelcy
11-21-2006, 12:05 PM
I used Earl's braided steel lines for a 1969 Camaro on my '68 with C5 front calipers.
crazyfireman
11-21-2006, 12:41 PM
Where do you get them and how much do they run??
Mkelcy
11-21-2006, 12:51 PM
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EAR%2D28A150ERL&N=700+400041+4294882683+4294908216+4294908198+4294 925082+115&autoview=sku
Use the C5 banjo bolts.
crazyfireman
11-21-2006, 01:01 PM
Wow 150.00 thats pretty steep for just the 2 lines, anyone have a low budget idea? I know shouldnt slack on Brakes but...
slowcamaro
11-21-2006, 01:47 PM
thats for the set. mine included the 2 front hoses and a rear hose. If i had it to do over id opt for another brand that has the coating over the stainless hose. It prevents dirt and grime from working its way into the weave, and continual fricton could lead to eventual fraying.
I believe goodridge is one of the companies selling the coated versions.
Mkelcy
11-21-2006, 01:56 PM
The board gave you the solution, pointed you to the web site that sells them and explained how the pricing works; did you want us to come over and install them too? :spank2:
crazyfireman
11-21-2006, 03:01 PM
Actually that would be great. I appreciate you pointing me in the right direction I was just looking for other options as everyone else does.
eville
11-21-2006, 04:11 PM
check touring-classics.
crazyfireman
11-21-2006, 05:14 PM
will do , thanks
crazyfireman
11-21-2006, 05:16 PM
85.00 for two, now we are talking!!
Steve68
11-21-2006, 06:18 PM
I got my Goodrich lines from Baer, a little more than $85 but I installed them last night, look good, and coated,
Steve68
11-26-2006, 06:08 AM
I would use the GM copper washers, I have found that all others leak!
Davezz28
11-26-2006, 03:13 PM
I have used KORE3 lines, give them a try kore3.com
crazyfireman
11-27-2006, 02:07 PM
exactly what I need, 60.00 for two!! Thanks Dave
crazyfireman
12-03-2006, 11:59 AM
Just ordered the lines from Kore3, 71.00 delivered. Sounds pretty fair to me, I also ordered the clear lines I will post pics when i receive them. Thanks for the help!
Tucks69
12-03-2006, 12:13 PM
I just ordered a set of brake lines from Kore3 also. They asked me the right questions to make sure I got what I needed. I ordered the black lines.
Mike
