View Full Version : anybody ever moved the bulkhead connector when smoothing firewall
tumper93
11-16-2006, 07:12 AM
I have installed the DSE kit on the firewall and just wondered if anybody had done anything different with the bulkhead connector on a first gen camaro. I would like to move it but not sure as to were it would fit. If the hole is filled then I could run a grommet through the firewall and clean it up some. Anybody done this using a factory harness?
67 455 Bird ragtop
11-17-2006, 07:18 PM
I'm at the same point also. It's been way too long since I took the car apart I forget what all is connected to those wires?? I assume you are taling about the plug, 2" diameter, just to the passenger side of the center of the car ??? If you could refresh my memory as to what those wire connect to I'd appreciate it.
