View Full Version : looking to maybe carb an LS1
DCx
11-14-2006, 02:51 AM
i really hate all the run around with the elctrical stuff. only reason i want to carb the LS1 is for the aluminum block. so my question is. if i score a clean take out engine that has all the electronics and stuff on it what are my chances of selling say the, stock intake, TB, fuel rails, wiring, and all that stuff. im pretty much after a complete long block, valve covers, coil pack mounts, and what ever odds and ends i need to make it work. it would be going in to a 69 camaro, so im sure im covered when it comes to motor mounts, headers, and other odds and ends. looking to add dart heads, cam, and so on. pretty much all the same stuff i got on my GEN1 engine.
so what can i expect to pay for a LS1 take out? looking to spend maybe $2000 on the engine and salvage what i can in parts in the forums to re coop the cost of the new parts. such as mds wires, rocker arms, and manifold with MSD Box.
its just an idea i got in my head.
thanks
justin
pist0lpete
11-14-2006, 03:12 AM
You will be hard pressed to find a low mile LS1 takeout complete for $2000. It is possible but you will have to search. You could find an iron block for the price easily but you want aluminum. As far as doing the carb setup goes its a proven performer and usually gains a little power up top. However, this is at the sacrifice of driveability, part throttle performance, throttle response, gas mileage etc. Not to mention the fact that you still have to run all the wiring and the LS1 computer. For what you pay for the carb and intake and ignition control box you could just about have your wiring harness modified by somebody like speartech and have your car tuned by your local LS1 tuner. Just some food for thought.
Steve1968LS2
11-14-2006, 06:42 AM
I still don't get the concept of going with a carb.. you will still need a computer (and wires) to run the coil on plug deal. You'll only save on not having to wire injectors. Also, when cleaned up there really isn't that much wiring. In fact wiring my LS2 was the easiest part of the deal.
And you will be able to sell the extra parts depending on what you get. Not much of a market for LS1 intakes. LS6 intakes yes..
I bought an LS1/4L60e combo for $2800 several years ago, so $2000 today is not out of line - but it won't be easy. You may also want to keep and eye on ls1tech.com (classifieds) since deals pop up there all the time for long blocks and such.
parsonsj
11-14-2006, 07:42 AM
you will still need a computer (and wires) to run the coil on plug deal.Not really. You can go with an MSD setup to run the ignition, or you can get a new front cover and run a distributor. GMPP sells that, or give Wegner (http://s41657.sites80.storefront-hosting.com/detail.aspx?ID=3291) a call.
The best reason I can see for ditching the factory computer and EFI is to allow easier tuning. If you use a carb and an MSD ignition, you're back doing tuning just like always with vacuum gauges, reading plugs, etc. It's doubtful (and probably impossible) to get a carb to be as drivable as the factory EFI, but that may a tradeoff lots of guys are willing to do.
jp
andrewb70
11-14-2006, 08:46 AM
Selling off the parts that you do not need will not be a problem. There always seems to be a market for stock intakes, TB, etc...
DCx
11-14-2006, 09:31 AM
From what i gather, the edelbrock intake comes with all the wires to make the ignition work. it also comes with a MSD box that takes pills like the 6AL. MSD just came out with a box that you pulg into a lap top and you tune away. also if i use LS1 headers with no O2s in them cant i hook up wide band for tuning?
here is a PDF for the MSD box
http://static.summitracing.com/global/images/instructions/msd-6010_frm26894.pdf
edelbrock PDF
http://static.summitracing.com/global/images/instructions/edl-290829087-carburetedvictorjr.pdf
very good read
http://www.superchevy.com/technical/engines_drivetrain/induction_poweradders/0409sc_gmpp/
so i guess im just looking for a good ls1/ls2 long block since i dont need anything else. i already planned on buying MSD wires and coil packs. are stock LS1 heads really all that great? or are after market the way to go? looking to make 500hp or more with off the shelf valve train. i would be reusing my 750 mighty demon.
Steve1968LS2
11-14-2006, 11:03 AM
jp
Yea, but how much will all of that cost? the adaptor to run the disty.. the MSD stuff.. the distributor itself.
lol.. tuning the factory ECU is cake once you get used to it.. and with the laptop you don't even have to get your hands dirty ;)
I just don't see the cost benefit.. he will sell of the unused LS1 stuff for pennies and spend $$$$ on all the carb/distributor conversion stuff.
All to gain some top end power and loose daily drivability (and mpg)..
Steve1968LS2
11-14-2006, 11:05 AM
Ported and reworked LS1 heads arn't bad.. LS6 heads however are better. The aftermarket heads are better if you are running FI or nitrous since they have thicker/stronger castings.
parsonsj
11-14-2006, 11:51 AM
tuning the factory ECU is cake once you get used to it.. and with the laptop you don't even have to get your hands dirtyOnce you get used to it? Of course that's true. On the other hand, if one is already used to tuning with a carb, then the carb/MSD/distributor setup is a viable option. And don't forget the cost of upgrading the fuel delivery system to run EFI.
Think of it this way: if I've got an iron block/iron head SBC and I want to step up to an aluminum block and heads plus some more power due to better head design I can go this route. It's cheaper than buying GM or aftermarket aluminum offerings.
Me, I'm not running a carb or the factory ECU: I'm running an aftermarket EFI with FAST's crank decoder and eDIST.
jp
DCx
11-14-2006, 02:04 PM
i also have a full built aluminum head, demon carb, yada yada, gen 1 motor in my car that has no miles on it. im just toying with the fact of building it in the corner of my garage out of spare time and money.
either that or i spend a butt load of money on a ricks gas tank, build a new short block, and add a D1SC down the road. either way its money.
it would be pretty cool to add A T56 down the line too. see i built my car totally old school. Iron block, aluminum head gen1 motor, auto gear m22. if i had the chance or the schooling sooner i would have went with the complete LS1 drive train. i cant even re use my clutch as the center force i have now is 10 spline. so considering the swap i would need an entire new drivetrain.
i still cringe at the fact of fuel injection. the painless chassis harness was enough to make me sick of wiring. like i said before. this would be for the weight savings as my car is more of a 1/4 mile type of deal.
it just dawned on me. how the heck would i used the muncie? there isnt a pivot ball on the LSX for mechanical clutch linkage.
parsonsj
11-14-2006, 02:36 PM
how the heck would i use the muncie?Use your existing bellhousing (if it's the big flywheel version). It will bolt to the LS1, minus the bolt hole at 2 o'clock. The spacing is the same. Not so sure about the pilot bushing/bearing, but maybe somebody else knows. If you want to step up, get a McLeod or Lakewood scattershield.
jp
Ron S
11-14-2006, 02:48 PM
There have seen stock bottom ends,fuel injected ls1's running low 10's,I've even heard a couple in the 9's on spray.I'm with Steve,why spend the money on all those aftermarket parts,when for about the same money you get the drivability and fuel economy of fuel injection. Ron
DCx
11-14-2006, 03:03 PM
i dont want to spend the cash on the fuel system or upgrade to an ECU. i dont care about gas milage.
im using a lakewood bell at the moment.
this isnt a bad deal. sell off the intake, wiring, TB, and what ever else. and come out with a decent engine.
http://cgi.ebay.com/ebaymotors/Complete-LS6-C5-Z06-Corvette-Engine-W-Harness-LS1-LS2_W0QQcmdZViewItemQQcategoryZ33615QQihZ015QQitem Z250047524953QQrdZ1
pist0lpete
11-14-2006, 03:19 PM
If you can think you can save money by going carb'd I would hate see you dissapointed. It may be possible if you can find all the car conversion pieces used at a great price but otherwise its not gonna save you money. If you are hardcore oldschool and only desire carb'd vehicles than more power to ya and good luck.
Steve1968LS2
11-14-2006, 05:03 PM
jp
You don't HAVE to upgrade the fuel system much if you're not putting out big power.. a $40 vette reg/filter and a sumped up tank with walboro pump is all you need..
:p
I just don't see it as being cheaper.. but it sure looks hella cool
Steve1968LS2
11-14-2006, 05:07 PM
Wireing my engine with my Speartech harness was the easiest part of the install.. took all of 40 minutes to plug it in.. lol
Haven't tired the Painless wire loom.. if you stick with all OEM stuff it's pretty cheap and easy to LSx your ride.. and not THAT expensive.
Back to the point of your thread.. I would try to find a cheap long block minus the stuff you don't need. Then you don't have to hassle trying to sell it. Watch ePay and LS1tech.com ... the deals are out there.
DCx
11-14-2006, 06:25 PM
im just keeping my options open.
i would part out or sell my current engine to make up for the cost.
how much did your wiring harness cost? arnt they close to $700 -$1000 just for the harness? also spending $600 on a DSE, ricks, or rock valley tank turns me off also.
Steve1968LS2
11-14-2006, 08:51 PM
Well you could go budget and sump a factory tank.. a guy here did that deal for $400 or so (can't remember)
Yea, the harness will cost you.. most likely a grand. But how much will all the carb stuff cost you? and you will need a system to control the coil on plug unless you buy the disty adaptor and that costs $$$ as well. In your case it sounds like you already have the carb.. just point out for others that a carbed LSx is not necessarily cheaper.
Please don't think Im trying to talk you out of it.. carb'd LSx engines are cool as hell.. just discussing :)
Van B
11-14-2006, 09:18 PM
jp
I have the pilot bearing. There were two recesses in my LS2 crank one small diameter and one larger the larger one is toward the back of the crank.
DCx
11-14-2006, 11:47 PM
i already have a 750 might demon carb. the msd box that comes with the edelbrock intake comes with the wiring to fire the coil on plug. there is nothing else needed but a carb, the intake, ignition box, wiring harness, coil packs, and 12v. the hook up for the box is just like a 6AL. The box has a tach lead, ground, and 12v power supply. other then plugging the boxs harness to the factory coil packs the wiring is a direct swap from the existing 6AL box i have wired in my car. making it such an easy swap.
the instructions state:
"The manifold includes an electronic Timing Control Module, which picks up MAP, Crank Position, Cam Position, and drives the stock Coil-On-Plug ignition system with the proper ignition timing."
i have looked at many sources on the net that took a fulie LSx, tore off the intake, installed the edelbrock intake, plugged box in to the harness to the coil packs and fired it up.
I posted the links above in PDF form on how to install the box. the edelbrock link has crappy pictures. the msd box has good info but doesnt show the intake install.
all in all sounds simple to me.
i have taken in consideration that i need an electric fuel pump, motor mounts, headers, and odds and ends like water neck, and maybe new power steering lines. see my problem is i have a drive train that needs re worked also. so im going to take a hit on that. as im sure it would be a pain to fab up a bracket for the clutch pivot ball for the mechanical clutch linkage. and the uncertainty of being able to use a muncie. because if i did swap to a t56 in the process i would need a new clutch. i built my muncie using a 10 spline main shaft. wish i had gone with the 26 spline.
DCx
11-14-2006, 11:59 PM
steve i understand what you are saying when i could have a harness for about a grand to run the efi, when the cost of the carb stuff is $700. not that big of a trade off really.
i just really dont understand efi. you cant do much with out the help of a dyno and a good tuner. My friend has a WS6 firebird and myself I have a 01 cobra mustang. Hes planning on modding the hell out of the Pontiac but cant do so without the help of a tuner.
i just like the fact that you can slap a new cam, and add a carb to a stock engine and pull off over 500hp. i highly doubt that my 355 can rev as high as a LS6 or make over 500hp. all that added HP comes at a weight loss advantage. so how much ligher is a LSx then an old iron block? about 200lbs? i cant imagine what it would be like to do a hole shot with all that weight off the nose.
only thing that gets me weirded out about this is the fact that i keep changing my mind as far as engines and things go. i havent even driven my car yet. it just sits in the garage. so i have no idea what kind of power its making. i just want to be different.
I spent the last few months getting it out of paint and wiring the chassis with a painless harness that isn’t so painless!
here is the link to my car. check it out and tell me what you think. There is a video somewhere in the camaros.net link below of it running.
http://www.camaros.net/forums/showthread.php?t=90303
ron79
11-15-2006, 03:12 AM
alot of us are looking at the carb set, msd just released the ls2 controler for 58x,and for ls1 you can get the edelbrock set up for 700 dollors,
Steve1968LS2
11-15-2006, 07:37 AM
So you will need the controler, the intake and the carb.. right?
ron79
11-15-2006, 09:44 AM
thats right you will need controler and intake and carb
DCx
11-15-2006, 12:18 PM
this is an option.
http://www.jegs.com/webapp/wcs/stores/servlet/category_10001_10002_76656_-1_10763
$5000 for a new carbed ls2
its a little steep but its a brand new ls2.
i did some more digging on the MSD web site and it looks like you still need the factory harness for the knock sensors and coil packs. does anyone sell JUST that harness in the after market?
Ron S
11-15-2006, 09:18 PM
Beleive me,we all felt the same way.It took a buddy of mine Frank,who bought a 98 f body ls1,bolted it to a turbo 400,and put it in a 63 chevy 11.That motor is about the lowest performing ls1 out there.He bought the painless harness,plugged the wires in,and took it to the track that night,with no computer tuning or mods at all,and layed down a 12.2 on radials,with factory manifolds .Since then with some mods and a healthy dose of spray,the car is just a hair away from breaking into the 9's.The car is very drivable and not really all that exotic.Although it hasn't been see out in way too long{If your listening Frank} Ron
00fxd
11-17-2006, 10:57 PM
I can see why a guy would want to use an LSx with a carb but I wouldn't . Modifying an existing harness isn't all that bad. My first and only efi conversion was a TBI on my sb400. I modifyed the original harness myself and I'm not into computer stuff, I'm old. I bought a mail order prom that seems to work quite well.
I am now looking for an LSx.
The only thing that intimidates me about the EFI is the pcm tuning. I would need lessons. What do you guys think about this service?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=330049142985&rd=1,1
The clutch cross shaft isn't a problem, there are several outfits that supply a bracket for the ball stud from the bell housing bolts.
Ron S
11-18-2006, 08:44 AM
Thats kind of what i was saying,If you leave it pretty stock there's no tuning needed.You would just need a vatts by-pass,and the painless harness has it in the harness.I think I have bought a couple of PCM's from a guy off ebay,that were supposed to have the tune I wanted in it.The pcm's were Ok,but the tune that was supposed to be in them was not right and the car wouldn't run.the guy said to send them back and he would make it good,but I just, had F body Centeral put a tune I wanted in them.
00fxd
11-18-2006, 06:21 PM
Thats pretty sweet about not needing to tune but don't you need to dis-able EGR and the second set of O2 sensors etc? For manual shift from an automatic doner remove the auto stuff, lock up etc? Might as well do that vats at the same time.
Ron S
11-19-2006, 09:49 AM
It will trip the check engine lite with egr and trans codes,but it will still go 12.20.
00fxd
11-19-2006, 11:27 AM
Thats sorta what I thought...... Thanks 5.7
