View Full Version : Another hydroboost question
68renner
11-10-2006, 09:26 AM
I know this topic has been beat to death but i've got some more. I've got a 68 camaro with a 396 BBC and manual brakes.
1st ? - Everybody knows how tight it is in a first gen with a BB. Does this cause any problems with the hydroboost itself or running the lines?
2nd ? - I have stock front disc and drum rear currently. Will the hydroboost still make a huge improvement with this setup? Is it worth the money to do the hydroboost for now and then work on saving money for upgrades?
3rd ? - I'm still not sure exactly how all the lines hook up to the power steering. They run directly to the pump correct? If so, how do you hook up the hydroboost and the power steering itself? I've looked at the other forums and instrictions, maybe i'm having a major brain fart but i'm still not sure.
Thanks for the help guys
Madspeed
11-10-2006, 10:26 AM
1. yes you will have room for it.
2. It should work better than what you have now.
3. line comes from pressure at pump to hydro then from hydro tosteering box. and the returns from box and hydro get tee'd back to pump ressivor
68renner
11-13-2006, 02:02 PM
thanks for the help madspeed
