View Full Version : Drum to disc spindle question
crazyfireman
11-09-2006, 03:01 PM
I have all I need to do the swap, but looking today when I slide the disc over the hub it looks like I wont have much of the stud left, do I need longer studs?
6'9"Witha69
11-09-2006, 04:06 PM
I assume you mean the wjeel studs? If so, I go by the track rules that there needs top be a few threads sticking out of an open lug nut when installed.
Tom Welch
11-09-2006, 05:59 PM
You will definitely want longer studs, I have used 12mm studs on my 67 firebird drum to disc conversion, it works and fits well so far.
ProBell
11-09-2006, 06:16 PM
If you used drum hubs you need to turn down the outside edge of the hub so the rotor goes up tight to the hub.
crazyfireman
11-10-2006, 03:55 AM
So I have to remove the hub, remove the studs and have it turned on a lathe?
69keith
11-10-2006, 07:35 AM
I turned on a ordinary brake lathe that I machine rotors and drums in the shop.
crazyfireman
11-10-2006, 08:33 AM
Ok, thanks
