Midnight68
10-31-2006, 06:02 PM
Has anyone used the Painless LS2 wiring harness? I am buying an LS2 crate motor. The Painless manual says this. Has anyone done these modifications to make this harness work?
If you have purchased an LS2 with an engine code other than those listed above, you can still utilize this
fuel injection wire harness after these engine modifications are made. Contact your local engine machinist
shop for help with these modifications.
1. The 58X crank shaft sensor reluctor wheel must be replaced with part number 12559353. This
replacement part number is a 24X crank shaft reluctor wheel from a 2005 Corvette LS2.
2. The crank shaft position sensor must be replaced with the part number 12560228.
3. The 4X camshaft sprocket must be replaced with part number 12576407. This is a 2X sprocket from a
2005 Corvette.
4. The cam shaft position sensor must be replaced with part number 12568983.
2005 Corvette.
