View Full Version : our current 65 stang vert project (56K no way)
absolom
10-24-2006, 10:17 AM
getting pretty close to being done, it's in paint right now
sorry, pics are kinda out of order and random
there's 4 pages of pics, so instead of posting 12 at a time, here's the link to the photobucket album
http://smg.photobucket.com/albums/v175/absolom/pearl%20pony/
heitd's MII front suspension, superide IRS rear suspenions, 427w stroker, T56, complete custom interior, etc etc
Restomod
10-24-2006, 03:32 PM
Great job ,I really like the way you are doing inside the trunk...nice!!
formula98
10-24-2006, 09:36 PM
Great looking project. I spent too much time looking at all your cool pic's!
Keep the updates coming!!!
projectPONY
10-25-2006, 06:13 AM
I'm assuming that you used automotive paint on your engine block, how is that going to hold up to the heat? might want to do that to mine. also, what type of wood is that in the trunk and it's thickness?
very nice work BTW
kmcanally
10-25-2006, 07:30 AM
Nice looking project...looking forward to seeing it finished.
absolom
10-25-2006, 07:59 AM
very nice work BTW
yeah, regular paint, we'll see how it holds up, but if it gets hot enough to ruin the paint, i'd be more worried about the engine
i think that's 3/8 wood in the trunk, it will be covered in vinyl though
formula98
10-25-2006, 01:13 PM
From what I've been told the standard automotive paints hold up well. My brother paints for a living and told me that the engine heat is not a problem, the exhaust gets hotter than the engine. Most automotive paints will hold up to 300 - 600 deg temps. The block temps are around 160 - 210 deg.
absolom
10-25-2006, 01:45 PM
yeah
if your engine block is over 600 degrees, you'll have a lot more than just paint to worry about
projectPONY
10-25-2006, 01:59 PM
well, I know headers get very hot, is the paint around the headers going to be damaged?
absolom
10-25-2006, 06:46 PM
hopefully not, we're using coated shorties, plus, the heads won't be painted, so maybe we'll be aight
absolom
10-28-2006, 02:41 AM
wahoo!
taking the 427w to engine dyno today
BADVELLE
10-28-2006, 06:04 AM
Car looks awesome, can't wait to see the finished product! Also, don't worry about the auto paint on the engine, either single stage or base/clear, I continue to use both, no issues. I actually like a single stage better, but the base/clear really comes out well after smoothing the engine/heads. Anyway, very cool car!
kmcanally
10-28-2006, 07:39 AM
wahoo!
Looking forwards to hearing how much power it makes. I got a W block in the garage that I am considering building into a 427W for my Coupe. So whose stroker kit did you use and what are the rest of the specs on the motor?
PhillipM
10-28-2006, 12:47 PM
You may have already thought about this but it appears in the pictures that your amp is mounted behind plexi? There could be possible heat issues unless you have a way to turn air over inside of there. We have this problem on a boat of ours that has about 5 amps on it, after about 2 hours of constant playing they like to get a little warm to say the least. -Phillip
absolom
10-30-2006, 06:08 AM
dyno results
EngSpd STPTrq STPPwr
RPM Clb-ft CHp
3100 517.9 305.7
3200 517.1 315
3300 510.4 320.7
3400 510.5 330.5
3500 507.8 338.4
3600 513.5 352
3700 517.7 364.7
3800 511.1 369.8
3900 511.5 379.8
4000 515.1 392.3
4100 517 403.6
4200 516.9 413.4
4300 507.7 415.7
4400 511.2 428.3
4500 509.9 436.9
4600 506.8 443.9
4700 500 447.4
4800 495.9 453.3
4900 491.4 458.5
5000 484.6 461.3
5100 481.5 467.6
5200 476.8 472.1
5300 469 473.2
5400 466.1 479.2
5500 459.5 481.2
5600 449.4 479.2
5700 441.4 479
5800 431.2 476.2
5900 429.1 482
6000 408.3 466.4
6100 390.7 453.8
6200 374 441.5
6300 364.9 437.7
6400 352.8 429.9
6500 344.7 426.6
absolom
10-30-2006, 06:10 AM
first fire
http://www.youtube.com/watch?v=jSfmEtJS9bs
first pull
http://www.youtube.com/watch?v=qTizdRQNT14
pics
https://static1.pt-content.com/images/pt/2006/10/IMG_2057-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2053-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2049-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2048-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2047-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2046-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2045-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2044-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2043-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2042-1.jpg
absolom
https://static1.pt-content.com/images/pt/2006/10/IMG_2041-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2040-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2039-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2038-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2037-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2036-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2035-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2034-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2033-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2032-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2065-1.jpg
https://static1.pt-content.com/images/pt/2006/10/IMG_2063-1.jpg
absolom
10-30-2006, 06:14 AM
coast high performance 427 stroker kit, all forged
out of the box vic jr. heads
1.7 roller rocker
hydraulic flat tappet cam, ~550 lift ~230/240 duration
air gap rpm intake
edelbrock 850 carb
afr was right on the money out of the box
we could have made a lot more power with a bigger cam, different intake, and some tuning, but we had a good safe tune, excellent torque down low, and we gotta worry about halfshafts :)
so we're pretty happy with it, and it'll loosen up a bit after a few thousand miles
kmcanally
10-30-2006, 07:41 AM
Dam I want one! Those are some pretty big numbers for a relatively small cam. Whats the compression ratio? And what year engine block did you use?
kmcanally
10-30-2006, 07:44 AM
I wonder how much power it would make with a .6ish
[email protected] solid roller cam and a Vic Jr. intake? I also wonder what it would do to that table flat torque curve?
absolom
10-30-2006, 07:55 AM
comp ratio is ~10.5:1
i think that's an 83 block, we have a few laying around, it's hard to keep straigh
lol
absolom
10-30-2006, 07:56 AM
yeah, i'm loving that torque curve
we don't have any data for under 3100, but from the rest of the data, off idle torque will be ridiculous
SatisTraction
10-30-2006, 01:56 PM
i bet it would pick up all the way across
