View Full Version : What fuel pump should I buy for an LS1/LQ4 swap?
dendrizzi
10-22-2006, 05:26 PM
I'm doing an LQ4 swap in my camaro, what fuel pump should I buy?
dendrizzi
10-22-2006, 05:32 PM
Also what pressure do they require?
dendrizzi
10-26-2006, 05:10 AM
I'm prob going to go with an External pump any ideas?
Aeromotive makes nice pumps as does Walbro. They need to be able to supply 60psi constantly. Just make sure the pump is at or below tank level so it gets good flow from the tank. I just did a FI convertion on a 73 vette and used a walbro pump that I bought packaged as an Edlebrock. Granted it only needs to supply 50psi constantly but its working perfectly fine. It's external and below tank level. The C3's flow fuel out the bottom of the tank though. You camaro comes out the top of the tank doesn't it? Shouldn't matter if it does.
ProBell
10-26-2006, 04:58 PM
I run the Aeromotive pump and it works fine once I got the pickups figured out in the fuel cell.
Randy
MooresGTO
11-28-2006, 02:25 PM
Walbro internal pump they make two or 3 different types. LS1 Tech which is a sponsor here would be alot of help.
