View Full Version : need info on 05 ls engine
nova69
10-19-2006, 04:27 PM
i bought a engine and trans. im tolded its from a rolled over 2005 trailblazer 5.3 2wd. my ? is the oil filter is in the middle of the oil pan and im not sure if my cross member is going to be in the way of the filter. would a different oil pan and pick up work or would i have to use the one thats on it now any help would be great thanks guys
Kenova
10-19-2006, 05:21 PM
You can use the pan, pickup, and windage tray from a Camaro or Firebird. The Corvette pan assemblies without the bat wings will work too.
There is a lot of info to be found at http://www.ls1tech.com/forums/
Ken
Scooter70
11-06-2006, 11:38 AM
Depending on where your crossmember is, the GTO pan might also work for you. It's a front sump. You can use whatever you want, just make sure that you match the pickup to the pan.
