View Full Version : flex line help
aany001
10-14-2006, 08:13 PM
hey guys I have installed speed techs front brackets with ZO6 calipers and C4 rotors and was wondering if anyone knows who makes a braided flex hose to fit a factory 69 camaro bracket to the calipers????
Also what master should I use????
thanks.
nancejd
10-15-2006, 05:50 AM
You should be able to order all the parts you need from inline tube. When I called to order and had questions about what I needed, they took the time to go through things with me until I had the parts put together. The only potentially tricky part is knowing what size banjo bolt you need for those calipers, but I can tell you that the LT-1 rear calipers are an M10x1.0 bolt, I suspect most of the modern calipers from GM would be the same.
chicane67
10-15-2006, 05:28 PM
Baer Racing also sells these lines on the shelf.
CarlC
10-15-2006, 08:06 PM
Russell also makes them.
aany001
10-16-2006, 05:55 PM
thanks for all the info guys!!
