View Full Version : 3-3/8" gauge angle rings?
Blown353
10-14-2006, 05:05 PM
As the title states, anyone have a source for angle rings for mounting 3-3/8" gauges? I see auto meter sells angle rings for 2-1/16" gauges, looking for something similar in the larger size....
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D2234&N=700+115&autoview=sku
Worst case I'll make my own but hoping I can find something off the shelf.
HILROD
10-14-2006, 05:13 PM
They also have 2 5/8, but I've never seen 3 3/8. FRANK
Patrick
10-15-2006, 06:01 AM
I ran into the same problem with my Jeep. I could not find angled bezels for a 3 3/8 gauge.. so I made them. I used a piece of 3.5 pipe cut to desired angle and welded it up. If you are working with plastic, I am sure you could do the same with PVC or some sort of plastic tubing.
Blown353
10-15-2006, 11:39 AM
Thanks for the pics Patrick. That's my plan, only I'll probably be using plastic tube. I'm building a custom face for my dash out of 1/8" textured ABS plastic because the texture is nearly a perfect match for the original dash material.
