    Results 1 to 20 of 25
      Who has used my brake info yet
      Ive give out at least 100 lists of how I did my brakes. Has anyone attempted it yet???
      Chesapeake, VA
      Sorry, but the new guy needs to ask, what do they fit?
      I dont know, but give me the list and ill do it next month. Please =)
      Nov 2004
      Eastern Washington
      ...or, got a link to a post where you describe it? Sorry for missing it. I have been in and out lately.
      Appleton,WI
      I hope to do the conversion on my '77 Pontaic Ventura this winter.
      This will work on 1968-74 Novas and Nova clones 67-69 Camaros some Chevelles.
      But with extra fab work should work on other years as well.
      There set up would work on most all GM 10 and 12 bolts with the 5 on 4 3/4 bolt pattern..
      Chesapeake, VA
      I've been looking through your old posts as well as links from those posts (like Chevelle Cheap Big Brakes). My application is Tri5 Chevy which most commonly uses an early Monte Carlo/Chevelle disc for conversions, with either matching calipers or later Metric A/G body calipers on a caliper bracket that bolts to the spindle. Looks like your approach should be adaptable to these cars as well? A drum brake hub would work just as well, wouldn't it?
      Jun 2005
      Stillwater Ok
      I plan to,I'm still looking for the S10 brackets on ebay.Looks like I might have to hit the junkyards
      I used rear brackets from this guy.. http://www.steeltechsolutions.com/RE...PAGE_CODE.html
      Jun 2005
      Stillwater Ok
      Thanks Again LowBuckX. BTW How did you set up your E brake?
      No e brake but this winter Im planning a pinion mounted E brake.
      Using a modded Gokart disc and caliper.
      Jun 2005
      Stillwater Ok
      I would like to know how that works out.
      Huntington Beach, CA
      erm, maybe my eyes are having trouble today but where does one find your brake info?
      Cumberland, Maryland
      Yeah you should put together a tech article. With part numbers/donor vehicle and prices. I already have c5 front swap started but some rear disks would be nice.
      Jun 2005
      Stillwater Ok
      Quote Originally Posted by blyth18md
      I agree do a article and have the Adm sticky it here.
      Aug 2005
      Hamilton, NJ
      Hell, give it to me and I'll throw it out on my old GeoCities site.
      Scott from NJ.
      Vent Windows Forever! ...
      So looks like no article done. How does one get a "list?"
      Danbury, CT
      I'd be interested in this myself, any input would be appreciated!
      1971 Cutlass Supreme
      1987 Grand National
      I lost track of this post ... Sorry. There is a little function called Private message. And I answer all of them with a list of part numbers.
      I wont do a tech article because Ive done that before with the Small Body HEI conversion wich turned into a PITA because of smart arse know it alls. I also didnt originate either project just did losts of reseach and peiced together info and ideas from other people and turned it from concept to reality.
      Heres some pics that i took. I didnt chronicle it because at the time noone cared about My LowBuck Ideas
      due to not every car/part being the same dont use my measurments as 100% correct
      clearance
      rear
      Did you use the same calipers front and rear?
      Do you have the part number for the calipers, either GM or the parts store numbers?
      What rotors are you running front and rear?
      Like I said though, im more interested in the rear end parts/prices.
      If you dont feel like doing an article; can you post up the parts list with prices and suppliers?
      thanks.
