View Full Version : Anyone make a kit with e-brake to run C6Z rears on a G-body with a 8.5" 10 bolt?
GinoRin
10-04-2006, 07:44 PM
Just like the topic says, I want to run the C6 Z06 4-piston rear calipers and 13.4" rotors on my 87 Buick GN and ditch the stock drums. Does anyone make a bracket kit with somethjing for the e-brake, or has anyone out there attempted to do this swap on the G-body yet??
Thanks!
Samckitt
10-05-2006, 02:36 AM
I have the C5 setup up front on 98-02 S10 Blazer "spindles". Somewhere I thought I read that the C6 ZO6 calipers will bolt onto the C5 knuckles without modification & use the larger rotors. If that is the case I may do that & make my own setup for the rear & replace the BAER brackets that use the 12" disc setup.
Samckitt
10-05-2006, 02:37 AM
Anyone have part numbers for the C6 ZO6 brake parts?
GinoRin
10-05-2006, 11:10 AM
here you go, scroll down the page for part numbers and prices:
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=C6
justanova
10-05-2006, 01:11 PM
I don't know if you guys have read any of the info in these threads below, but it may be a good Idea before getting all gung ho' on the c6 z06 brakes. the z06 brakes are probably pretty good but others have diff. opinions.
chicane has some good info in the thread from lat-g
http://www.lateral-g.net/forums/showthread.php4?t=5750&page=3&pp=10
https://www.pro-touring.com/forum/showthread.php?t=22066
