View Full Version : Body Bushings
69slotcar
10-03-2006, 07:55 PM
Does anyone have the Body Bushing thickness dimensions (the ones that go between the subframe and body on a First Gen Camaro) for:
1.) Stock Rubber
2.) DS&E
3.) Global West
Stock / Lowered Heights
aonghus
10-03-2006, 08:46 PM
I'll get the measurements for the stock height solid DSE bushings when I get home in a couple hours
*edit* when I get home this afternoon..
68Formula
03-06-2009, 02:17 PM
Guess he never went home.
Anybody know the answer? I think my body mounts are too short. They measure .625" thick (from what I can tell on the car).
Radlark
03-06-2009, 04:45 PM
I don't know why that had me busting a gut as I looked at the date it was posted :hah:
JEFFTATE
03-06-2009, 05:23 PM
Maybe he PM'd the answer ??
ProBell
03-06-2009, 06:42 PM
I think I used the DSE solid mounts. The only one I can get to is the back of the frame. It looks to be a 1/2". Hope this helps.Randy
joeelutz
11-08-2009, 03:03 PM
I have a new set of stock body bushings. As far as the part that goes between body and frame or frame and radiator support, 4 of them measure 5/8" and two measure 7/8". I'm not sure what location the 7/8" bushings go, but would really like to know.
dipren443
11-08-2009, 04:18 PM
The like 4 go between subframe and body. The other pair are for the core support.
joeelutz
11-09-2009, 04:18 PM
Well the odd thing about that is the 4 that are the same thickness are thinner than the other 2, but look at this pic of DSE body mounts and you will see that the like 4 are thicker than the other 2. So I'm still a little confused.
http://www.detroitspeed.com/images/Body/body_mounts_pic.jpg
dipren443
11-09-2009, 09:18 PM
You are looking at the two pieces there. The part of the bushing that goes between the frame and body is what you want to measure. The taller bit you see is the lower half that doesn't contribute to subframe height in relation to the body. You cant really see mine now that my subframe connectors are in, otherwise I would take a pic for you.
joeelutz
11-10-2009, 04:10 PM
I understand exactly what you are saying, but is the part of the DSE bushing that has the curved sides the part that goes between body and subframe or the part that goes below the subframe? I thought the taller part with the curved inward sides is the part that goes between the body and frame.
Thanks for the help.
dipren443
11-10-2009, 04:51 PM
Negative. The part with the curve goes on the underside. The other piece indexes on the frame. If you had the DSE bushings in hand, you would know exactly what I am talking about. If I had CAD on this machine, I would make you a nice 2D layout.
I am curious how well I can see mine... If I can get a decent pic under the car, I will snap a few.
:twothumbs
joeelutz
11-10-2009, 05:37 PM
OK that makes more sense. I thought the curved part indexed the frame. Thanks for clearing that up.
dipren443
11-11-2009, 08:05 AM
Had a spare minute at work.
joeelutz
11-11-2009, 04:20 PM
Nice drawing!
susniand
03-10-2010, 11:14 AM
can you add a dimensions to the drawing, would help a lot of people, thanks.
