View Full Version : Anyone Running an LS Truck Block
GBodyGMachine
10-03-2006, 05:01 PM
I was just wondering how popular the Iron 6.0l's are. I am seriously thinking about running one. I can get them for a pretty good price. I have heard they make good numbers.
Jeff
XTRMEASURES
10-03-2006, 05:11 PM
whats a good price?
have any pics?
GBodyGMachine
10-03-2006, 05:32 PM
Good, $1500-$1800 motor/trans/t-case/harness
No pics.
protour_chevelle
10-03-2006, 05:58 PM
I'm running a 6.0l.
Its quicker then my buddies 72 Short with a LS1/4l60e and 3:07s
Mines a 6.0l/4l80e with 2:73's(and we all know how blah that is off the line, especially with the 80e)
how many miles on the set-up?
-Matt
GBodyGMachine
10-03-2006, 06:04 PM
I dont know. I have a co-worker that can get them.
Jeff
dendrizzi
10-04-2006, 05:21 AM
The 6.0 is what I'm planning on running. I figure my current setup is a GEN1 SB with aluminum heads so I will not have to change my front spring rates. There have been 6.0's out of Denali or escalade on ebay with computer wiring and all assesories for $1999.99 buy it now...
dendrizzi
10-04-2006, 05:23 AM
If your guy can get for them that cheap and can get more then one, please tell me I'm intersted.
TT402LS1
10-16-2006, 09:44 AM
Im running a 02 6.0L. Bought mine for $1000.00 with only 26K on it.
rocketman
10-16-2006, 10:55 AM
I'm building a 422 Lsx using a 6.0 block.
Ron S
10-16-2006, 11:33 AM
I've got a 6.0 in my 68 Camaro,I just like the Iron blocks better
Zedzag
10-16-2006, 11:41 PM
I just dropped an LQ4 that I built up in my 81Z last weekend. I bought it as a low mile long block that a guy hydrauliced(sp?) and bent two connecting rods. The core yard had 6 or so LQ4s so I found a couple rods of the same weight and built it up. The cool thing about the '01 and newer engines is the fact that they come with the 317 aluminum heads which flow very similar to the LS6 heads. The iron block can be bored to at least .30 over and with it's 4.00" bore, the newer L92 or LS7 heads will bolt up too!
68redcamaro
10-18-2006, 06:21 PM
I put an 2004 LQ4 6.0 from a Denali with 3000 miles on it in my 68 camaro. I got it for $1500.00. I took it to the track and it ran best so far 12.06 @112.8mph. I put a small upgrade cam Futral F6 and LS6 intake and thats it.
dendrizzi
10-19-2006, 04:14 AM
Where did you get the engine for $1500? Also did it come with accessories computer etc?
68redcamaro
10-19-2006, 07:01 PM
A freind i know buys and sells wrecked cars and trucks. The vehicle my engine came out of was burnt in the rear. I got engine and computer but no acc.
He has a 2001 transam 6 speed with 50,000 miles right now for $3500.00 for the whole car. It has been hit in the side so the engine bay is perfect.
Terry
6'9"Witha69
10-20-2006, 11:55 AM
Where is this friend? Or where are you?
68redcamaro
10-22-2006, 07:16 PM
Baton Rouge La.
68ls1wannabe
10-22-2006, 07:28 PM
What are you guys doing about the front drive accesories? I think you have to change water pumps to get the LS6 intake to bolt up. Best price I have found is a 02 LQ4, 20000 miles, oil pan to intake with harness for $1800. I don't think you can use the oil pan in a 68 camaro cause it hangs to low. I'm trying to find a aftermarket pan right now. Did you guys use the stock wiring harness or aftermarket? Has anyone used the painless harness?
00fxd
11-18-2006, 12:00 AM
Apparantly the F body pan doesn't hang as low. You will need the pick-up as well.
sjg34
11-18-2006, 05:49 AM
The front of the sump on the F-body pan had to be notched for clearance on mine.
InMotionJosh
11-18-2006, 07:30 AM
I got an awesome deal on a lq4 two weeks ago. I had to drive to pick it up but it was worth it. It came out of a 02 wrecked HD silverado. It had 35000 miles. Its complete minus the alternator and came with the 4l80e still bolted to it. I only plan to use the engine in its current condition to mock some stuff up in the car, then it will be torn down, bored and stroked to a 408 and single turbo.
I got the whole package for $1200!
00fxd
11-18-2006, 05:32 PM
I tried to edit my post. I see it didn't "take".
Yes, I belive the F body pan needs some "notching" to fit the 1st gen Camaros. But it'll fit just fine in my 2nd gen Corvette :-)
InMotionJosh
11-19-2006, 08:11 AM
anyone know which pan will fit the 70 chevelle with no mods?
andrewb70
11-19-2006, 08:50 AM
As far as I know noone of the stock pans will fit an A-body. Moroso and Milodon just announced steel pans that will work in an A-body.
TT402LS1
11-20-2006, 06:37 AM
There is a company that makes mounts that sits the motor back far enough to use a stock F-body pan. I think the company is called BMR. Anyway, the engine ends up being REALLY close to the firewall.
andrewb70
11-20-2006, 08:16 AM
Ahhh..yes.. I believe Matt is using that setup. Maybe he will chime in.
TT402LS1
11-23-2006, 03:14 PM
Heres some pics of my truck motor...
jsconiers
11-24-2006, 12:25 AM
how did you fit your gm block to the viper t56? I was told that you can't mate (or at least the cost would be crazy) an ls1 / lq9 with the viper 6 speed.
TT402LS1
11-24-2006, 06:26 AM
McLeod makes a kit. The Viper input shaft is 1/4" longer. With this kit they use a spacer, than the bellhousing. All under $500.00
Thanks - Ron
TT402LS1
11-24-2006, 06:57 AM
Here a pic...
68ls1wannabe
11-28-2006, 12:33 PM
Where can I find one of these really good deals. Apparently mine wasn't that good. I really like saving a buck.
