View Full Version : Big Block Fun
TonyHuntimer
09-30-2006, 04:42 PM
If you had to build a Big Block Chevy engine between a 427 and a 510 for a Pro-Touring car, what would you build and what kinds of parts would you put in it?
Thanks for your input,
Tony Huntimer
RaceHome.com
LowBuckX
09-30-2006, 11:17 PM
IM bored so I will play with you on this subject.
Block__ Donovan Aluminum. to keep weight down Would save 140 bls off the nose
Crank__ Howards 4.00 stroke.
Rods__Howards Ultimate billet Or Dyers 6.385 length
pistons__ CP 4.600 bore
= 509 CID 8"1 compression
(Not sure if rod with fit short deck but hey where playing)
Heads would be
Merlin "Jenkins" 310 rec port heads 2.25 intake 1.88 exhaust
A Paxton Novi Blower
A cam with about 286/296 duration .750+ lift
An intercooler with 110% efficiency
Im thinking 1000+ Hp
realistic no usefull power for street tire No.. but would be fun. :3gears:
Lowend
10-01-2006, 10:14 AM
Ben's 496 works really well on a factory block. I don't think I could find a better bang for the buck
TLWiltman
10-01-2006, 12:05 PM
More of a "streetfighter"-type setup, but I'll play.
-Donovan AL block (4.500 bore)
-3.75 crank (477cid w/short stroke to help cut down some of the low end torque). Lunati, Callies, HTC
-6.535 Oliver billet rods (1.74:1 rod/stroke ratio). With a tall-deck block, you could go to 6.935 (1.85:1 rod/stroke ratio).
-Fully ported AFR 357. Chamber as small as practical.
-Pistons to give ~11:1 compression (1/16-1/16-3.16 ring package)
-Total seal "max seal" rings
-Solid roller ~260/266 @.050 ~.700 lift 108-110LSA (I don't worry about power brakes or an auto trans.)
-DRY SUMP!
-1050 king demon on fully ported (wilson manifold single plane)
816hp @ 7500
665ft-lbs @ 5500
over 400ft-lbs from 2000 to 7500+
Area under the curve. Dynosim came up with a wierd one (as it usually does).
Camshaft
275/297 adv duration
116.5 LSA
115 ICA
824hp @ 7500
697ft-lbs @ 5500
another option that would seem to work well
Comp XR292
292/297 254/260 @.050 .660/.666 lift 110LSA
812hp @ 7500
673ft-lbs @ 5500
That's with open exhaust
With mufflers, you'd be looking at a nice 750hp/650ft-lbs... give or take
