GregD
09-29-2006, 09:08 AM
Hello all, I'm having a bit of a problem with my car. I apologize for the length. 68 Camaro, 383, edelbrock 1406 carb, MSD RTR distributor. The car started running rough the other day and I'm trying to troubleshoot. I had let the gas tank get pretty empty so initially I thought I might be running out of gas. However, I have since filled the tank and I'm still having the issue. I then thought I might have sucked up some crud from the bottom of the tank. I checked the fuel filter and there was quite a bit of crud in there. I cleaned that out but am still having a problem. The problem is somewhat strange. At times, the car runs great for a few seconds then it feels and sounds like its losing a few cylinders. I lose power, it stutters a bit and occasionally backfires slightly. Then it will come back to full power as if someone just just flipped a switch. The best way to describe it is that its like someone is throwing a switch and the car runs great, then they throw the switch and it runs really poorly. Its really that pronounced. Would a fuel issue cause something like that? Because its such an on/off type of problem it leads me to question whether I have some sort of ignition problem rather than a fuel problem. I did find something strange. When I measured voltage at the coil, I'm only getting 11-11.2 volts while the car is running. With the car off, I'm getting 12.4 volts. This is without any electrical accessories running. Do you think this is a problem? Can I run a jumper wire directly from the alternator post as a test to see if that solves the issue? The wire is currently run up from the starter post. I measured voltage at that starter post while the car is running and it shows about 12.4 as well. I looked at the wiring and did not find any shorts or cracks. Any help is appreciated.
BTW, output at the alternator post is good at 13.7 volts.
