View Full Version : Anyone mini tub with Wayne Due irs?
ilovefirstgens
09-19-2006, 01:09 PM
Well im just wondeirng if anyone has minitubbed their car with the wayne due irs. Ive got the irs but my "builder" mentioned i should do it and be able to fit a 315 out back. Im planning on a front sub in the future, it would be awesome to run a 275 front 315 rear setup. I just wanted to see if anyone has successfully done it.
Note: this would be WITHOUT relocating the dog bones.
68fusion
09-19-2006, 03:05 PM
If you have a nine you can do the 315. Have done this to an eight and as much as we could squeez in there is about a 305 and not have any worries. All depends if you move the trailing arms in about an inch. We are working on making a billet piece to "capture" and support, while spacing in.
ilovefirstgens
09-19-2006, 03:10 PM
im assuming you are saying 69 and 68?
I really wana go with a 315 on a 10.5" rim, the tire choices for 305s suck to say the least....
ProdigyCustoms
09-19-2006, 04:09 PM
You will have to narrow the rear to fit the larger tires because the dog bones have to move in
ilovefirstgens
09-19-2006, 04:23 PM
Well right now ive got quite a bit of room between the dog bones and the tire, and if i had the means to narrow them id throw a 335 in haha.
estamato
09-20-2006, 11:20 AM
I am building a similar project.
I am shortening the rear end replacing almost all components fitting in the 335's with the mini tub.
What year rear end did you pick up? There is a difference in the track width depending on the year.
I am assuming you are talking about the C4 setup IRS correct.
ilovefirstgens
09-21-2006, 12:38 AM
yes its from a 85 so the narrower setup.
ProdigyCustoms
09-21-2006, 02:07 AM
Here ya go. Not a Wayne Due kit, but a narrowed C4 with 345s
estamato
09-21-2006, 07:46 AM
Super Nice,
Now if only someone could post a build up!!!!
Let's get technical.....
P.S. Thanks Prodigy for that pic!
