View Full Version : 18x10 on a 68 firebird?
DippedInSauce
09-18-2006, 07:44 PM
Can I fit an 18x10 on a non tubbed 68 bird? I want to get rid of the 20's
mone
09-18-2006, 08:38 PM
How much u sellin em for?
within1sreach
09-19-2006, 06:11 AM
Please PM price or post it and where your located.
within1sreach
09-19-2006, 06:19 AM
What tire size your running front and rear and why do you want to change.
rocketman
09-19-2006, 09:19 AM
a 285/35/18 should fit.
DippedInSauce
09-20-2006, 08:21 PM
In case it's unclear I'm running a 20/18 combo. Rear is 255/35/20 front is 225/40/18. The post was to see if anyone had info on running an 18 x 10 wheel on the back (sorry if I was brief or unclear) for example back spacing. I know it will have to be precise as it will be a tight fit. I will most likely sell the two 20 s if I can get an 18 x 10 successfully mounted. I'm in the SF Bay Area CA. Thanks
mone
09-21-2006, 05:53 PM
What size is the rear 20 inch wheel width wise?
Wall
09-21-2006, 06:04 PM
Well "HOT OHC" is running a 17x10 w/ a 5.75" BS but I don't know all the specifics on his car although I'm 95% sure he isn't mini tubbed. You would probably have to do some trimming and nail the backspacing to fit 10's. With that being said from all the searching I've done on here it seems that every car is not the same so the best thing to do is measure your car youself to see what will fit. You can do a search on backspacing to see how to do it.
ill steez
10-07-2006, 12:05 PM
you can run an 18x10 with 5.75 inches of backspacing, as long as your fender lip is completely trimmed off or rolled.
DippedInSauce
10-21-2006, 04:19 AM
Thanks to all who gave input. I'm still hoping for the 18x10 but others off this forum swear up and down that I will have problems and a 18x9 is my best bet. Unfortunately the good people at American racing go from 18x8 straight to 18x10. I think this might be a sign from above that it is time to step on up to a quality wheel (TT2's are quite crappy for the most part).
muthstryker
10-21-2006, 05:50 PM
and that is why they arnt on this forum :D haha there are ppl here that have done it.
ill steez
10-25-2006, 06:31 PM
well all im saying is that you can do it. s long as your fenders are trimmed or rolled you WILL be fine with 10 inch wide wheels.
JLM
11-17-2006, 09:31 AM
Drewhelm on this board fit 18x10's in the rear of his 69. I believe he was right at a 6" backspacing and ran a 295 tire.
You'll need to measure yours to be sure as every car is different, but you should be able to do it. Might have to trip the inner finder lip, but that shouldn't be too much of an issue.
68Formula
11-17-2006, 10:45 AM
True, but doesn't the body lines on a '69 allow for a little more clearance?
tripower
11-17-2006, 03:59 PM
That's the same issue I have with my 65 GTO...18x8 TTs classics all around and the step up is 18x10. That would be very tight on a 64-65 A-body too.
JLM
11-17-2006, 08:20 PM
I'm not sure on that one.
Depending on how low the car is I would almost assume that the 67 and 68 cars might have more room as the wheel doesn't get tucked inside.
There is another member OHC Bird, or something along those lines that is also running an 18x10 on his bird which is a 67/68 car.
xx_ED_xx
11-19-2006, 02:27 PM
what size are the 20's width backspacing etc and did you sell them?
rocketman
11-19-2006, 06:44 PM
Ho wwide is your 20,if it's an 8 inch,measure 3 inchs and see what you hit,that will tell you.
DeepBlue68
11-19-2006, 09:12 PM
You might wanna check out this thread: https://www.pro-touring.com/forum/showthread.php?t=10840
I know it's a Camaro, not a Firebird, but you still might find some of the info in there useful.
Karch
12-24-2006, 10:55 PM
Tripower, if you don't mind me asking, where in SoCal do you live?
I've had my 65 Tempest (GTO clone) for 20 years and could use some inspiration.:offtopic:
Thanks. By the way, I'm in West L.A.
pontiac455
04-24-2013, 07:58 AM
So what is your backspace on rim on back and in front
