View Full Version : Spindle measurements c4 corvette
wildvj
09-03-2006, 09:49 PM
hey all,
Im chasing some spindles for my chrysler and my options down here in aus are a bit limited in what i can buy.
Im going to build a double a arm front end to replace the torsion bars with so i can do some track days and hill climbs so it handles better
Now to the point of the story, what im after is could some one do some measurements on some c4 spindles for me, what i need is could you measure the distance between the top and bottom ball joints (outside to outside faces) and also the distance fromt the bottom ball joint to the centre line of the hub so i can work out some rough positions on the car to see if these will work.
Ultimatley id like some afx spindles but unfortunatley the budget wont stretch that far when i can get some vette ones from trusty ol ebay on the cheap.
If some one thats running these could take a few specs for me i'd be really greatful
cheers sean
ps see attached crappy image
paul67
09-04-2006, 12:11 AM
Theres different types depending on year
VenturaII
09-04-2006, 08:21 AM
85 Corvette. Outside balljoint flush mount surfaces are right at 9&5/8". Lower balljoint mount to centerline of hub is right at 4&5/8".
wildvj
09-04-2006, 01:11 PM
Thanks VenturaII, Much appreciated, that helps a fair bit, by any chance do you know if the 84 ones are the same??
cheers sean
VenturaII
09-05-2006, 02:20 PM
No, I don't know if they are all the same or not. One difference is the newer ones (86 & up) have a hole for anti lock brake sensors.
paul67
09-05-2006, 04:00 PM
They altered the length of the upper and lower control arms so they are not a straight fit on the 67-79 camaro well on my 96 1s anyway would they be C5 ?.
Obsin71Ls1
09-05-2006, 07:34 PM
the dimentions on the left are off a 95 corvette.
Kenova
09-06-2006, 07:40 AM
What is the spindle on the right from? Looks like Camaro, but I can't be sure.
I'm also wondering if there is much difference in the king pin angle.
Ken
wildvj
09-06-2006, 12:52 PM
Thanks for those specs obsin71Ls1,
that really makes things easy,
its good when you can take measurements on the car and you dont even have the parts sitting there!!!
much appreciated
cheers sean
Obsin71Ls1
09-11-2006, 05:19 PM
much appreciated
cheers sean
you are welcome
What is the spindle on the right from? I'm also wondering if there is much difference in the king pin angle
2nd gen camaro spindle. i don't know the specific #s on the kingpin inclination angle on the 2 spindles but visually they seem close.
Twin_Turbo
09-12-2006, 11:43 PM
can you post a larger pic of just the C4 spindle so I can see the kingpin inclination and other specs? Thanks,
Marck
Obsin71Ls1
09-14-2006, 09:34 PM
Marck
unfotunetly that diagram does not include the measurement for the kingpin inclination angle. if you want, i can post an actual pic of the c4 spindle I have.
