View Full Version : help! plz (drum brakes)
muthstryker
09-01-2006, 07:40 AM
well i have the day off today and i went out side to move my car forward and i think the e brake is on.. i dont know why in hell it would be on but last night i pulled it out of the garage and it rolled just fine and this moring nothing froze..is there any way i can check this or get it to roll again? im going to run to the rental store and pic up a huge lift so ill check back later. thanks guys.
Matt, Look under the car to see if the ebrake cable has tension on it.If you didnt pull it it shouldnt but thats the best way to make a quick check.Or you could jack up the rear and see if the rear wheels are locked. Tim
muthstryker
09-01-2006, 12:40 PM
the ebrake cable dont have tension on it its really loose..
Madspeed
09-25-2006, 10:41 PM
Did you eveer get to the bottom of it?
was it rusted backing plates? or corroded wheel cylinders?
muthstryker
09-27-2006, 07:33 PM
the cable was rusted and i didnt want to use it again so i just cut the damn thing and took the breaks off. not using them anyways. frame was stripped and powder coated.
