View Full Version : rear disc 70
whistle74
08-25-2006, 08:37 PM
have 70 chevelle with 12 bolt rear end and have a complete rear out of a 2000 camaro with discs.Would it be possible to put the camaro discs on the 12 bolt and if so what else would be needed.
67LSRS
08-26-2006, 08:07 PM
Call BRP they have adapter brackets to get those on early GM 10 and 12 bolts.
http://www.brphotrods.com/
shep
08-26-2006, 08:28 PM
They bolt on the only thing you might need is a spacer between the axel flang and the caliper bracket. You will need longer bolts for the caliper bracket. Then you need to figure out the ebrake cables.
