View Full Version : Comp Cams Magnum Roller Rockers
TZmtrsprt
08-25-2006, 05:11 PM
I'm looking to upgrade my rockers on a 1970 LT1. I'm checked out the Comp Cams Magnum roller tip rockers and they look like a good replacement. Anyone have a history with these rockers with a solid lifter cam? I am only looking to change the rocker arms and push rods. Thanks in advance, TZ
rocketman
08-26-2006, 01:08 PM
there good,i've never had a problem with comp cams,one thing to remember is will the valve springs take the added lift,you don't want them to coil blind
TZmtrsprt
08-26-2006, 01:17 PM
Thanks Rocket. I think I will order new sprngs too, so I'll be sure to check them out also. Thanks again, TZ
Lowend
08-26-2006, 03:16 PM
IMHO the roller tipped rockers are a waste of money. The roller tip dosen't really roll so much as slide
I like the Pro-Magums myself. Full roller rocker, strong, light and rebuildable.
http://www.compcams.com/technical/Catalogs/106-07/269.pdf
